Nohenns Posted March 13, 2015 Share Posted March 13, 2015 Hey guys, recently my car got t-boned. Luckily the other car missed my rocker so frame damage is at a minimum but my door on the other hand is ruined. I was wondering if their is a difference between early second gen legacy doors and mine which is a 98 lgt. The only reason I'm asking is because I know that the early legacy's had different front bumpers than later second gen legacy's. Basically I am planning on pulling off my doors and seats and other panels so I can get my frame straightened and reinforced. Link to comment Share on other sites More sharing options...
johnegg Posted March 13, 2015 Share Posted March 13, 2015 95 - 96 REAR doors are different than 97 -99. fronts are the same. sedan and wagon doors are the same for the same model year. but the rear door glass is different between the two. so make sure you have a matching glass if you are swapping in between the two. Link to comment Share on other sites More sharing options...
Nohenns Posted March 13, 2015 Author Share Posted March 13, 2015 Thanks Link to comment Share on other sites More sharing options...
johnegg Posted March 14, 2015 Share Posted March 14, 2015 there is a nother difference i forgot to mention. the separate lock button on the front doors. 95 - 96 do not have the separate ''lock / unlock'' button on the front doors. (the interior door cards a different.) i do not know how the wiring harness might be different, or not. of if the 97 door card with lock button will plug into the 95 harness. but the metal door frames, windows, and lock hardware are the same for the fronts, 95- 99. i kind of like the 95- 96 locks, when you lock or unlock the driver door from the inside, it locks all the doors. it just does it with the lock button at the ''door open'' handle, not a separate lock button. Link to comment Share on other sites More sharing options...
Nohenns Posted March 16, 2015 Author Share Posted March 16, 2015 This came just in time since I just finished pulling off every thing about an hour ago. Link to comment Share on other sites More sharing options...
Zues Marine Posted March 16, 2015 Share Posted March 16, 2015 there is a nother difference i forgot to mention. the separate lock button on the front doors. 95 - 96 do not have the separate ''lock / unlock'' button on the front doors. (the interior door cards a different.) i do not know how the wiring harness might be different, or not. of if the 97 door card with lock button will plug into the 95 harness. but the metal door frames, windows, and lock hardware are the same for the fronts, 95- 99. i kind of like the 95- 96 locks, when you lock or unlock the driver door from the inside, it locks all the doors. it just does it with the lock button at the ''door open'' handle, not a separate lock button. yeah......i swapped in a '96 driver's side door into my '95.... the harness' arent the same, i lost mirror control and the 'follow-me' locks window control and speaker/tweeter harness remain compatible though Link to comment Share on other sites More sharing options...
twisty Posted March 20, 2015 Share Posted March 20, 2015 i put 98 wagon doors (passenger side front and rear) on my 96 sedan, used my existing glass, harnesses and locks and everything worked out well. except the paint match. Link to comment Share on other sites More sharing options...
johnegg Posted March 20, 2015 Share Posted March 20, 2015 the ''security bolt'' receiver on the rear door did not cause any problem? in 97 they added a big black bolt on the rear door jamb, half way between the door latch and the bottom of the door. and there is a corresponding ''receiver'' on the door itself. it appears to be for cage integrity during a crash. the 95 -96 years do not have it. as a result the the 95 - 96 doors will not bolt onto the 97 - 99 years with out removing the bolt. but i'm glad to hear that the receiver does not stop the 98 door from bolting onto the 96 car. Link to comment Share on other sites More sharing options...
twisty Posted March 23, 2015 Share Posted March 23, 2015 no problems for mine, i dont even remember having to take the bolt off. my son probably did tho, i showed him the differences before we installed, he did most of the work. Link to comment Share on other sites More sharing options...
