TDWPgtp Posted February 25, 2015 Share Posted February 25, 2015 I am in the process of replacing my struts, springs, and strut mounts, and upon assembling the strut assembly, I noticed that the BRAND NEW strut mount bearing has a fair amount of wiggle in it. I do not recall the old OEM mount having any wiggle, and was wondering if this is ok/normal or if I just wasted money and time on garbage parts. Any help is appreciated. Link to comment Share on other sites More sharing options...
TDWPgtp Posted February 25, 2015 Author Share Posted February 25, 2015 Additionally, does anyone have any experience or opinion regarding MOOG vs KYB vs anything else? the old OEM mounts still seem pretty solid, and at this I am considering just putting those back on... Link to comment Share on other sites More sharing options...
ras06LGT Posted February 25, 2015 Share Posted February 25, 2015 What kind of wiggle? The whole mount is rubber and will move. Are you referring to the steering bearing having movement? Link to comment Share on other sites More sharing options...
TDWPgtp Posted February 25, 2015 Author Share Posted February 25, 2015 I'm not sure the best way to explain...With the strut assembly together, but not on the car, if I put my hands on the strut mount and push down on one side and pull on the other, the whole plate will pivot without any real effort. It looks like the bearing itself is loose, although it is hard to tell. As I said earlier, the OEM ones did not do this at all. I should note that if I simply pull up on the mount, it does not move...It IS tightened all the way down. Keep in mind that these were $25 each. I already filed a return request and decided to get a different brand. I guess the more important question now is what brand should I buy? Link to comment Share on other sites More sharing options...
TDWPgtp Posted February 25, 2015 Author Share Posted February 25, 2015 I found a coupon for my local dealership, so I ordered OEM replacements anyway. On a related note, I have read that KYB manufactures the OEM struts for these cars. Is there any validity to this? And, if so, do they also manufacture the strut mounts? Link to comment Share on other sites More sharing options...
ras06LGT Posted February 26, 2015 Share Posted February 26, 2015 I found a coupon for my local dealership, so I ordered OEM replacements anyway. On a related note, I have read that KYB manufactures the OEM struts for these cars. Is there any validity to this? And, if so, do they also manufacture the strut mounts? Yes, KYB is the OEM replacement strut. Not sure if they make top mounts as well, but OEM will be your best bet. Link to comment Share on other sites More sharing options...
