Mat_Mandangle Posted February 2, 2015 Share Posted February 2, 2015 I'm pretty sure my gasket is blown between my CNT DP and stock cat-back, and I already have the 3-2.5in adapter gasket. I am skeptical that the stock bolts will be long enough to reuse, does anyone know the proper sized bolts for this kind of fix? Thanks, -Mat Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2015 Share Posted February 4, 2015 Any 3/8 bolt nut and washers from the hardware store will work. You don't need the OEM bolts. get the bolts about 2" long and get some large OD washers. I have better luck not using the support bracket from the tranny. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
