Phyte Posted January 20, 2015 Share Posted January 20, 2015 Hello there, I recently bought an 02 legacy gt. The car is great, I've had to do a couple minor things to it but nothing to major. Since I've bought it however there has been a knock in the engine, I thought it was piston slap but after searching and researching I've changed my mind :/. It does it when idling, cold is loudest but then the noise changes. It seems to be coming from the center of the engine towards the rear. I've looked at engine noises and cannot seem to find a description to match the noise. It mainly does it when idling, while moving its only noticeable in from about 1500-2300 rpm. I know this has been asked a million times and I've read countless articles on it but I cannot seem to match it with a problem. Please help! I posted this on sli but apparently no one on there is active :/ and no one on nasioc.com answers me. I'm Almost starting to think it's not an internal engine noise just cause of the fact that it doesn't fit the descriptions of knocks or anything. Please help me! If it's piston slap, just tell me that and call me an idiot. I love my subaru and can deal with the noise, I just want to know if this is gonna be a motor swap fix or an easy weekend project. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 20, 2015 Share Posted January 20, 2015 Could be a failed rod bearing aka rod knock or a loose pulley. When you change the oil next time, look in the drain pan for metal flakes they will be the size of oatmeal flakes or slightly smaller and copper in color. If you find them or not and you rule out the easy to diagnose issues you may be in for a rebuild Link to comment Share on other sites More sharing options...
Phyte Posted January 20, 2015 Author Share Posted January 20, 2015 Well I changed the oil a couple weeks ago, I didn't look for shavings at that time cause I was still convinced it was piston slap. I was kinda thinking rod knock but I just thought it was weird that it doesn't get louder with engine speed and only does it with acceleration and Idle, down shifting through the same rpm range doesn't seem to make the noise, and it's less noticeable with lighter throttle, or with heavier throttle. It kinda sounds like it's coming from where the engine and tranny meet almost. I'm assuming the metal shavings I would find would be ferrous? So I can magnet the bucket of oil and pull em out? Edit: it also seems to only be noticeable in gears 1-3 Link to comment Share on other sites More sharing options...
Phyte Posted January 21, 2015 Author Share Posted January 21, 2015 I scraped the bottom of the pail of my used oil and searched in the pan I used, with both my hands and magnet, nothing stuck in the magnet, and other than some dirt, grime, and dust, I found nothing. No chunks, no slivers, and no flakes, to be honest I couldn't even find shavings, in terms of like tiny bits. I dono guys, is there any other options it could be? Or any other tests I can run to rule stuff out or narrow in on it? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 21, 2015 Share Posted January 21, 2015 Is your harmonic balancer in rough shape?? Link to comment Share on other sites More sharing options...
Phyte Posted January 22, 2015 Author Share Posted January 22, 2015 Last time I watched it, it didn't wobble at all. I'll check again a little closer tonight. If it doesn't wobble is there any other way to check it? Also the sound seems like it's from where the engine meets the tranny. At idle anyway. Would the harmonic balancer be able to effect that? Link to comment Share on other sites More sharing options...
vto Posted January 22, 2015 Share Posted January 22, 2015 Subscribed to this, I have the same issue and have an auto, will let you know if I find anything to help with this Link to comment Share on other sites More sharing options...
Phyte Posted January 23, 2015 Author Share Posted January 23, 2015 Update, since today was a bit warmer after work, I turned the heat off and the radio off, and when going up the rpms in 3rd gear, the sound doesn't go away, but turns more into a whirr/grr vibration noise. It doesn't actually vibrate, just sounds like it. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 23, 2015 Share Posted January 23, 2015 Can you get a sound clip if possible? Link to comment Share on other sites More sharing options...
Phyte Posted January 24, 2015 Author Share Posted January 24, 2015 Of the noise while driving? Ya I'll try to get one. You did see the YouTube links on the bottom of my original post right? Link to comment Share on other sites More sharing options...
Phyte Posted January 29, 2015 Author Share Posted January 29, 2015 Well I took some crap videos, that pretty much a lot of ruffling, but you can hear it in the background, listen for the clack clack black ink the past few days it's been 35-40 degrees out and the noise has been gone or very quiet. Maybe it is piston slap http://youtu.be/nuQ7GaI436M Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 29, 2015 Share Posted January 29, 2015 Sorry i missed the two links up top (reading fail ) in the video it sounds like a rod bearing or something in the valve train almost like too much clearance or a bad lifter. Link to comment Share on other sites More sharing options...
Phyte Posted February 12, 2015 Author Share Posted February 12, 2015 Ya I was thinking lifter or valve train just cause it's only a certain rpm and doesn't necessarily get louder through higher rpm Link to comment Share on other sites More sharing options...
