Ohoen Posted January 18, 2015 Share Posted January 18, 2015 For my 05 GT. It's the piece made up up two sleeves welded into a cross. One is totally seized. Probably why the shifter shaft seal was leaking. I'm trying to get the car back together. I think my dealer may actually be some kind of group home in disguise. The other day I had to come up with numbers for the axle seals because they couldn't handle that task. So, anybody got a part number for this? Or, better yet, an online source? I can't find anything but I don't actually know what it's called, so that makes searching a bit hard. I'd really appreciate any help. Link to comment Share on other sites More sharing options...
Ohoen Posted January 19, 2015 Author Share Posted January 19, 2015 Well, after soaking it for half a day it all came apart. I'm going to try to clean it up and see if it will work, or maybe I can just get the bushings separate. Link to comment Share on other sites More sharing options...
DanielLGT Posted January 25, 2015 Share Posted January 25, 2015 Here you go, just bought one, now trying to find some sort of instructions on how to install it. 35046AG000 http://opposedforces.com/parts/legacy/us_b13/type_5/manipulation/manual_gear_shift_system/ Link to comment Share on other sites More sharing options...
heiche Posted January 26, 2015 Share Posted January 26, 2015 Here you go, just bought one, now trying to find some sort of instructions on how to install it. 35046AG000 http://opposedforces.com/parts/legacy/us_b13/type_5/manipulation/manual_gear_shift_system/ In that pic, #1 is a double roll pin. Knock the inner one out, then knock the outer one out. They are tight. Also remove bolt #9. At that point it should be removed. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
