jakeafton Posted January 16, 2015 Share Posted January 16, 2015 Third bearing has gone bad in 2 years. Last time a machine shop charged me $50 to press out the old and press in the new. I had already bought the parts and did everything else, all I did was bring them the bearings and seals and my knuckle. The time before that I had Les Schwab do it for like 900 million dollars. Let's say I buy a press, or know someone who has one I can use, is it difficult to press out the old and press in a new? How much pressure does it take, as in how big of a press? Use wood or something between the bearing and metal?...anyone ever done this before that can point me in the right direction I'd really appreciate it. I have everything I need, I even bought a new hub. Link to comment Share on other sites More sharing options...
johnegg Posted January 17, 2015 Share Posted January 17, 2015 a ''hub tamer'' type tool is better. a press can distort the housing unless it is supported correctly. and i have heard horror stories where 12 tons would not budge one. but i think that is very unusual. Link to comment Share on other sites More sharing options...
Osei Posted January 17, 2015 Share Posted January 17, 2015 If you have to pay that much, I would buy a complete spindle from salvage. Just making sure the ball joints and bearings are good. Around here it's $60 and soooo much time and work are saved. O. Link to comment Share on other sites More sharing options...
Gus_Colorado Posted January 19, 2015 Share Posted January 19, 2015 I disagree. Depending on the car, taking the knuckle out is the majority of the work. Then you replace with a new knuckle with an unknown bearing that can be already bad to start with. I just pressed mine myself with a 5 ton press. It wasn't very easy, but not too hard. Other than having a press you need a bunch of scrap thick metal to support the knuckle and a bearing pressing kit from harbor freight (30 bucks). I believe that if you are spending time and money on a job, you better do it right and only once. I saved money on advance half axles before just to have them clicking again in a few weeks. Now I have to redo the job and put decent axles there. At least they are warranted for life so I will get my money back. Link to comment Share on other sites More sharing options...
