need bb Posted January 8, 2015 Share Posted January 8, 2015 Today was really cold and every time after shifting into a new gear and disengaging the clutch I would hear a metallic sound. The sound was triggered when I let up about 1/2 way on the clutch pedal after the clutch pedal was fully depressed. It seemed to be originating under the dash/foot well. Any ideas? Link to comment Share on other sites More sharing options...
Rhitter Posted January 8, 2015 Share Posted January 8, 2015 The clutch shaft (term) goes through the firewall right above the accelerator pedal and frequently makes squeaking noises. There is also a clutch return spring right above clutch pedal that makes noises. I shoved myself into the footwell and started pressing on the clutch to track down and stop the noises. My OBXT build Link to comment Share on other sites More sharing options...
need bb Posted January 10, 2015 Author Share Posted January 10, 2015 Thanks. I assume this is more of a nuisance than foreshadowing a mechanical issue? Link to comment Share on other sites More sharing options...
Rhitter Posted January 10, 2015 Share Posted January 10, 2015 Mine was just a nuisance. But it took me a while to figure out when the squeak was coming from. I think I ended up greasing 3 areas (two in the cabin and one on the transmission) before the squeak stopped. The Throw-out bearing can also make the noise that foreshadows clutch failure and was why I tried to track down the noise. http://legacygt.com/forums/showthread.php/clutch-squeal-throw-out-bearingi-143812.html How many miles on your current clutch? At 90k my clutch failed and the pedal ended up on the floor. If you are anywhere around that you might be due for a new one soon. My OBXT build Link to comment Share on other sites More sharing options...
need bb Posted January 11, 2015 Author Share Posted January 11, 2015 The sounds isn't really a squeak, it sounds like a metal on metal on contact. Clutch is new with only 3K miles on it. Link to comment Share on other sites More sharing options...
FJuan Posted January 13, 2015 Share Posted January 13, 2015 That spring behind the clutch petal needs lubing up every blue moon. Mine would creak and squeal a little, but after lubing it, it went away. Test it by having the motor turned off and pressing on the clutch pedal, you'll have a better understanding if it's coming from the pedal or bell housing. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
