Rush600 Posted December 31, 2014 Share Posted December 31, 2014 The dipstick for the oil keeps popping out on my 05 lgt, spewing oil all over the engine. I can't figure out why. I just replaced the gasket on the dipstick itself and it fits snug but that didn't help. Anyone have any ideas? Car is stock except for cobb intake Link to comment Share on other sites More sharing options...
MrTris Posted December 31, 2014 Share Posted December 31, 2014 Your crankcase pressure is too high. Check your PCV valve. Link to comment Share on other sites More sharing options...
gimpydingo Posted December 31, 2014 Share Posted December 31, 2014 Your crankcase pressure is too high. Check your PCV valve. None of the classic, remove that intake!? Link to comment Share on other sites More sharing options...
MrTris Posted December 31, 2014 Share Posted December 31, 2014 None of the classic, remove that intake!? Intake isn't the problem here, the crankcase pressure is. Link to comment Share on other sites More sharing options...
SpecBFan Posted December 31, 2014 Share Posted December 31, 2014 PCV Sent from a controlling box in my pocket Link to comment Share on other sites More sharing options...
Rush600 Posted December 31, 2014 Author Share Posted December 31, 2014 The pcv was replaced about 6 months ago, could that still be the problem? Link to comment Share on other sites More sharing options...
MrTris Posted December 31, 2014 Share Posted December 31, 2014 OP, you would be wise to replace your PCV valve. It's not too hard, just take off your TMIC and it's right below there. Hardest part is the hose clamp that's near the block. Getting it back on is a bitch, not gonna lie to you about that. Otherwise, it's pretty straightforward. The part is about $30, and it'll take you a couple hours or so to replace it - Many vendors here, like msprank or Underdog would have it in stock and ready to ship to you. Link to comment Share on other sites More sharing options...
ttnio Posted December 31, 2014 Share Posted December 31, 2014 I would replace the PCV valve assembly first, before anything else. Thank you Mr.Tris Happy New Year.! Happy New Year All.! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 1, 2015 Share Posted January 1, 2015 Sounds like me.. I replaced my PCV (before the oil dipstick issue) and next thing I knew a few weeks later it pops up.. However I will admit it has stopped doing it now but it makes a total mess. Link to comment Share on other sites More sharing options...
theflystyle Posted January 5, 2015 Share Posted January 5, 2015 I dont remember if the Legacy had a rubber oil ring on the dipstick but I know my SVX does. When the SVX was having its dipstick pop (PCV was good) I just changed the o-ring and it stayed put. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 5, 2015 Share Posted January 5, 2015 Sounds like me.. I replaced my PCV (before the oil dipstick issue) and next thing I knew a few weeks later it pops up.. However I will admit it has stopped doing it now but it makes a total mess. Didn't you have ringland issues though? I believe cracked ringland can also cause the dipstick to pop out . Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 8, 2015 Share Posted January 8, 2015 I never said anything about a ringland issue I know the rings for sure. . However when I get the new block and swap I will tear down the old block. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 8, 2015 Share Posted January 8, 2015 I just assumed that is what you had from the following discussion we had on one of your threads: U can also do what I called the puf puf test where u take the oil cap off while idling and see if u see vapor pulsating in phase with the rpm. If u only see some vapor at first and no pulsating afterwards u should be OK ringland wise. But if it pulsates in phase with the rpm, then it's no good It goes in phase with the rpm.. im deciding if I want to do a used ej255 block for like $500 or ej22e with the 255 heads The other thing is to remove the pistons but not too keen because I've only taken one motor apart and it was just a learning session. . My biggest fear is getting the wrist pins back in place Then I hope you don't have that issue then. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 8, 2015 Share Posted January 8, 2015 It's no big deal a new SB from the dealer will take care of that.. I will tear down the old block later in the year. Link to comment Share on other sites More sharing options...
