bkv348 Posted December 31, 2014 Share Posted December 31, 2014 I recently installed a invidia catless dp there is no exhaust leaks and everything seemed to be running smoothly, until the check engine light came on. It running rough in cylinder 1 and 2, and it read a 1 on my cobb ap don't quite understand what the numbers mean. What could be the cause of this. I have a heat shield on the turbo but the dp is not wrapped, could it because it's too hot? My guess is no because I live in northern mn. Please comment what you think it could be. Link to comment Share on other sites More sharing options...
magnusonsubie Posted December 31, 2014 Share Posted December 31, 2014 I know it sounds stupid but did you flash the correct map? 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
bkv348 Posted December 31, 2014 Author Share Posted December 31, 2014 Yes, stage 2 lwg 91 octane. Link to comment Share on other sites More sharing options...
