Bigben12034 Posted December 28, 2014 Share Posted December 28, 2014 My 05 lgt running stage 2 has been fine at 1.0 dam for ever then suddenly down to .4 for about 15 minutes after start up, then back to 1.0. Any cause for concern for this? Or any reason? Thanks Link to comment Share on other sites More sharing options...
SleeperScoob Posted December 28, 2014 Share Posted December 28, 2014 Did you remove or disconnect the battery just before this happened? DAM should stay at 1.0 at all times unless you've just reflashed the ECU. Cobb tune or Pro/E-Tune? I'm sure someone will chime in with some enlightenment past what I can provide. Link to comment Share on other sites More sharing options...
