ashwinearl Posted December 27, 2014 Share Posted December 27, 2014 Can someone post some pics or describe the right way to put the engine undercover back on. I did a coolant flush and after putting the undercover back on, I've got this rattle that occurs at low speeds. Do I need to make sure the front edge of the undercover sits on the outside of the front bumper. Link to comment Share on other sites More sharing options...
gimpydingo Posted December 29, 2014 Share Posted December 29, 2014 Don't think there is a wrong way to put this on. Just make sure all the holes line up, then put the plugs back in. Should hold nice and tight. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 29, 2014 Share Posted December 29, 2014 Front popit holes sit UNDER the front bumper tabs with the popit holes. Make sure it's clicked into place in the center on the crossmember and then don't forget the two shoulder bolts in the front behind the bumper mount. Link to comment Share on other sites More sharing options...
