Soarin Posted December 26, 2014 Share Posted December 26, 2014 Bone stock 06 Legacy GT and it's cold in northern Nevada so I have the heater on to 74 on both sides. Driving around and things are great then I pull into a space, put it in park, turn off the heater, and the revs stay at 1,000 and don't go down to the usual 750-800 after driving. Nothing else weird is going on and this is new to me. This is an occasional thing and has only happened a few times. Any advice? Should I worry about it? Is it an HVAC thing? Link to comment Share on other sites More sharing options...
Soarin Posted December 26, 2014 Author Share Posted December 26, 2014 Not sure if it matters or not, but the few times this thing has happened have been on short trips on city streets. Short trips being around 4 to 5 miles in distance. Link to comment Share on other sites More sharing options...
apexi Posted December 26, 2014 Share Posted December 26, 2014 I'm guessing this happened when the engine was cold and after the car had been sitting for a bit? iNVAR posted the attached image in the thread below. My guess is the engine wasn't able to heat up as much as it usually does due to the short trip and the colder weather. So when you reached your destination, the coolant temperature was only at around 130F so the car wouldn't let the idle drop below 1000rpm. http://legacygt.com/forums/showthread.php/high-idle-cold-p4253190.html Link to comment Share on other sites More sharing options...
Soarin Posted December 26, 2014 Author Share Posted December 26, 2014 Yep, the first time this happened it was sitting in the garage overnight and tonight it sat for two hours in a cold parking garage. I went looking around the forum for this kind of thing and found the same chart while thinking that I was probably overthinking this. That totally makes sense. Thank you. Link to comment Share on other sites More sharing options...
MrTris Posted December 26, 2014 Share Posted December 26, 2014 You need a new shortblock. Link to comment Share on other sites More sharing options...
JJr Posted December 26, 2014 Share Posted December 26, 2014 Trissy Link to comment Share on other sites More sharing options...
MrTris Posted December 26, 2014 Share Posted December 26, 2014 I like OP's av. I wonder if he's a Brony. . . Link to comment Share on other sites More sharing options...
CloudSeed777 Posted December 26, 2014 Share Posted December 26, 2014 You need a new shortblock. You must be in IT. Just reboot. Link to comment Share on other sites More sharing options...
MrTris Posted December 26, 2014 Share Posted December 26, 2014 You must be in IT. Just reboot. I grew up servicing Win95 and 98 machines; back then, if there was a problem, the answer was always: Reinstall the OS. Link to comment Share on other sites More sharing options...
boxman Posted December 26, 2014 Share Posted December 26, 2014 I like OP's av. I wonder if he's a Brony. . . First thought I had as well. Link to comment Share on other sites More sharing options...
gimpydingo Posted December 29, 2014 Share Posted December 29, 2014 I grew up servicing Win95 and 98 machines; back then, if there was a problem, the answer was always: Reinstall the OS. I've re-installed Win 98 more times than I would like to remember. Link to comment Share on other sites More sharing options...
