grizzlyfarmer2 Posted December 24, 2014 Share Posted December 24, 2014 Over 30mph I get a howling noise in the car, thought it was the directional tires I had on, but with new tires and 4 wheel alignment, it is no different. It has been this way for 10-15k miles, not certain its really gotten worse over that time either. Would it be a wheel bearing, or the rear differential? I'm fairly certain it's coming from the rear half of the car. Maybe a driveline issue? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2014 Share Posted December 24, 2014 Ride in the back seat while someone else drives the car, you can hear a lot better back there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ras06LGT Posted December 26, 2014 Share Posted December 26, 2014 The rear wheel bearings are notorious on these cars for failing. Depending on your mileage I wouldn't be surprised if they were starting to fail (or have already began to fail). Link to comment Share on other sites More sharing options...
MyWifezLEGi Posted December 29, 2014 Share Posted December 29, 2014 Correct me if I'm wrong wasn't there a recall on the bad wheel bearing for the early years. I had mine replaced but it was a noticeable sound u can hear. Link to comment Share on other sites More sharing options...
BoyceWare Posted January 1, 2015 Share Posted January 1, 2015 My 07lgt had a bad rear right wheel bearing. It sounded like a car with a crappy exhaust was in the distance. Link to comment Share on other sites More sharing options...
grizzlyfarmer2 Posted January 2, 2015 Author Share Posted January 2, 2015 Was the LR wheel bearing. Bolted the new bitch in to find a stud with the wrong thread pattern, beat the shit out of the old studs trying to get the hub assembly off, was 11:30pm and I was out of beer and drunk. Now I have an ABS light on, where do the wires run for the ABS sensors? I didn't see one around the outer hub. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 4, 2015 Share Posted January 4, 2015 Look in the wheel bearing thread. http://legacygt.com/forums/showthread.php/diy-rear-wheel-bearing-replacement-walk-through-w-pdf-188666.html Which brand hub did you use ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
grizzlyfarmer2 Posted January 5, 2015 Author Share Posted January 5, 2015 I went with the Master Pro from O'reilly's. ABS sensor on order, broke the tip off the old girl. Thanks for the thread link, couldn't find it. Link to comment Share on other sites More sharing options...
