alyolles Posted December 24, 2014 Share Posted December 24, 2014 Need new rims because current ones are bent. Looking at a used set on craigslist but not sure weather i should get them or not because i dont want to have the same issue i have now. What would you guys do? Also anybody have any recommendations for places to get cheap rims? Link to comment Share on other sites More sharing options...
freaksavior Posted December 24, 2014 Share Posted December 24, 2014 I went through this last week. I bought a wheel off rockauto for 135 and then bought a used tire from a shop. Cost me about $250 total. Link to comment Share on other sites More sharing options...
alyolles Posted December 24, 2014 Author Share Posted December 24, 2014 Any idea why these rims bend so easily? Link to comment Share on other sites More sharing options...
freaksavior Posted December 24, 2014 Share Posted December 24, 2014 If I had to guess, I would say low profile tires + pot holes. These are also aluminum wheels, and aluminum is soft. These wheels have lasted almost ten years in Houston on my car, and Texas has some really poor roads. So one wheel in ten years isn't bad. Link to comment Share on other sites More sharing options...
MrTris Posted December 24, 2014 Share Posted December 24, 2014 Tirerack has some pretty good specials going on. . . Link to comment Share on other sites More sharing options...
alyolles Posted December 24, 2014 Author Share Posted December 24, 2014 Is there any way to tell if a rim is slightly bent when it is not on the car? Link to comment Share on other sites More sharing options...
MrTris Posted December 24, 2014 Share Posted December 24, 2014 Is there any way to tell if a rim is slightly bent when it is not on the car? There are wheel balancing machines at tire shops. . Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2014 Share Posted December 24, 2014 Have you talked with a wheel shop ? we have some close which will straighten the rim for around 50-80 dollars. They can even fix curb rash. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Vetteman Posted December 24, 2014 Share Posted December 24, 2014 Got my replacement wheels from the Rack. They have very reasonably priced wheels - they even have one that looks somewhat like OEM. Having had a tire give its life to protect the rim (big gash) from a pothole, I decided to go with more rubber on slightly wider rims - running 235/45's. Car looks better, IMO, the wheels fill the wheel arch better, and obviously there is more rubber on the road. Link to comment Share on other sites More sharing options...
boxkita Posted December 24, 2014 Share Posted December 24, 2014 moved to wheels section - free bump Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
alyolles Posted December 24, 2014 Author Share Posted December 24, 2014 Have you talked with a wheel shop ? we have some close which will straighten the rim for around 50-80 dollars. They can even fix curb rash. What wheel shops are experienced enough/willing to bend a wheel back correctly? Link to comment Share on other sites More sharing options...
MyWifezLEGi Posted December 29, 2014 Share Posted December 29, 2014 U have to look around in your area, here in socal there's a few. But after factoring the repair + mounting dismount. It might be cheaper to source a used one. Bent my stocker on a nasty pothole . sometimes you can't avoid them. Link to comment Share on other sites More sharing options...
