krot84 Posted December 17, 2014 Share Posted December 17, 2014 Hey all A while ago I've started noticing that when i press the HVAC damper position button and set it to "feet" or mixed "face/feet" it doesn't work as it should. It starts making a ticking sound like the valve/damper has trouble changing to the desired position. When i change it to "feet only" it keeps all the wents open and i feel the air coming through the center vents too, when it should only come from the side vents and the button ones. Has anyone come across such a thing? P.S. I have the dual zone climate control HVAC. Thanks Link to comment Share on other sites More sharing options...
rhino6303 Posted December 19, 2014 Share Posted December 19, 2014 Yes. Your mode actuator is shot. Link to comment Share on other sites More sharing options...
CatInTheDryer Posted December 19, 2014 Share Posted December 19, 2014 This thread shows the part in question and how to fix it if you have the patience. I recently pulled the driver's side blend actuator out and refurbished it (regressed the gears, pulled the copper contacts out to increase the tension on the sensor, hit the tips of the contacts with 1000 grit sandpaper, and cleaned the sensor). Before I did this, the actuator was constantly clicking...now it works perfectly and is silent again. Link to comment Share on other sites More sharing options...
krot84 Posted December 19, 2014 Author Share Posted December 19, 2014 Thanks, I've read the whole thread. i'll try to work it out when the weather is better. Link to comment Share on other sites More sharing options...
