D-VO Posted December 12, 2014 Share Posted December 12, 2014 Subject is pretty much the conclusion I have come to. I get a vehicle speed related noise coming from the center of the car. I think the center diff does not like the new fluid. Front and rear diff were done at about the same time with the recommended Mobil1 75W90 fluid. I guess my questions are two-fold: Is this going to damage the center diff over time? Or just be annoying Aside from changing the fluid again, is there anything else I should do? I'd like to not drop the pan if I don't have to. Any help is appreciated... Link to comment Share on other sites More sharing options...
robinlsb Posted December 12, 2014 Share Posted December 12, 2014 Subject is pretty much the conclusion I have come to. I get a vehicle speed related noise coming from the center of the car. I think the center diff does not like the new fluid. Front and rear diff were done at about the same time with the recommended Mobil1 75W90 fluid. I guess my questions are two-fold: Is this going to damage the center diff over time? Or just be annoying Aside from changing the fluid again, is there anything else I should do? I'd like to not drop the pan if I don't have to. Any help is appreciated... Auto or manual? Year?? It makes a BIG difference "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
D-VO Posted December 12, 2014 Author Share Posted December 12, 2014 Ah, apologies. 2005 LGT Wagon, 5EAT, 102k miles. Link to comment Share on other sites More sharing options...
Vetteman Posted December 12, 2014 Share Posted December 12, 2014 What did you put in the transmission itself, as against front and rear diffs?? Link to comment Share on other sites More sharing options...
D-VO Posted December 13, 2014 Author Share Posted December 13, 2014 I had a local shop just do a drain and fill with some standard ATF, I'm not sure which brand. Level seems fine. Link to comment Share on other sites More sharing options...
robinlsb Posted December 14, 2014 Share Posted December 14, 2014 I had a local shop just do a drain and fill with some standard ATF, I'm not sure which brand. Level seems fine. Standard ATF?????? Was the filter replaced? How many quarts? Sounds like they changed 1/2 the trans fluid. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
D-VO Posted December 15, 2014 Author Share Posted December 15, 2014 Filter was not replaced. Have an appointment at the Subaru dealer tomorrow to re-do this. I have a 1000 mile trip to take this weekend and I'm out of time to screw with it myself. Link to comment Share on other sites More sharing options...
D-VO Posted December 17, 2014 Author Share Posted December 17, 2014 So.... trans was fine. Culprit was a rear wheel bearing. Again. After I just replaced them four months and 2k miles ago. Link to comment Share on other sites More sharing options...
ktmrider Posted December 31, 2014 Share Posted December 31, 2014 So.... trans was fine. Culprit was a rear wheel bearing. Again. After I just replaced them four months and 2k miles ago.Out of idle curiosity what brand hub assemblies did you use? OEM or aftermarket? Link to comment Share on other sites More sharing options...
D-VO Posted January 1, 2015 Author Share Posted January 1, 2015 The garbage Autozone brand. I paid the $100 for the nice version (Timken or SKF I think) this time around. So far no issues with 1k miles on it. Link to comment Share on other sites More sharing options...
