QuadraTokn Posted December 8, 2014 Share Posted December 8, 2014 I just bought a 2005 Outback with the 2.5. The car wont crank over because of the high speed CAN communication error. The previous owner left a new ECU in the car and he also replaced the starter/battery wiring harness. I dont know if he had the ECU programmed but I installed it and the car still doesnt crank. The temp gauge is pegged at high. I dont hear the fuel pump cycle on. I've reseated the bulkhead, checked all the grounds, checked the battery, the green connector near the ECU is unplugged, etc. The CEL is NOT on nor does it flash while cycling the ignition. No blinking cruise light either. Could be the bulb?.. but I tried taking the instrument cluster apart but it obviously doesnt come apart all the way. So the CEL is NOT on but I have 3 codes: P1709 throttle position sensor circuit high input: the input signal circuit of accelerator pedal position sensor is shorted P1714 throttle position sensor power supply circuit: the power supply circuit of accelerator pedal position sensor is open or shorted P1718 can communication circuit Link to comment Share on other sites More sharing options...
Merc6 Posted December 9, 2014 Share Posted December 9, 2014 "ER HC" and the owner "left a loose ECU in the car" sounds like the ECU is bricked. Go to the passenger floorboard where the carpet goes up and stop. Pull it back and make sure the 2 green connectors aren't still connected. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Zac88 Posted December 9, 2014 Share Posted December 9, 2014 Check the grounding block on the back of the drivers side intake manifold Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted December 9, 2014 Share Posted December 9, 2014 I had that message after a rebuild and it ended up being a loose ground on the intake manifold (tgv). The throttle position code makes me think it's wiring as well, but the whole "left a loose ECU in the car" should raise some questions. Best of luck Link to comment Share on other sites More sharing options...
Bbc84 Posted December 11, 2014 Share Posted December 11, 2014 I had that error happen on my 05' GT but not the additional codes. What happened to me was the turbo wastegate bracket or heatshield bracket cut into the engine harness by passenger firewall and shorted some wires for me. repaired the ecu harness wire then replaced a blown fuse in the box under the hood. Fuse was shaped one like this: http://contentinfo.autozone.com/znetcs/product-info/en/US/bsm/BP-FLF-30-RP/image/3/ Car started fine afterwards. Also while researching before finding that was the issue, seems that the ECU under the passenger seat carpet gets wet from either leak through firewall or maybe condensation. My ECU cover was a bit rusty on the bottom and inside rust was working its way towards the edge of circuit board, so it could be that too. Link to comment Share on other sites More sharing options...
QuadraTokn Posted December 11, 2014 Author Share Posted December 11, 2014 All the loose Ecu means is that he tried replacing it and that didn't fix the problem. He also replaced the battery harness. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 12, 2014 Share Posted December 12, 2014 OP, fyi the instrument cluster has LEDs. So it is very unlikely that one of them will go out. Link to comment Share on other sites More sharing options...
K2e2vin Posted December 12, 2014 Share Posted December 12, 2014 Mine was also a blown fuse, but under the dash. Coil wire had shorted(broken connector). Link to comment Share on other sites More sharing options...
