GeorgeB Posted September 13, 2005 Share Posted September 13, 2005 what type are the diferentials on the legacy 2.5i ? tks Link to comment Share on other sites More sharing options...
Xantium Posted September 13, 2005 Share Posted September 13, 2005 front and rear are open. Link to comment Share on other sites More sharing options...
GeorgeB Posted October 25, 2005 Author Share Posted October 25, 2005 so let's say, that you get in a position , that you have 0 traction on a front wheel , and 0 traction on a back wheel. what then ?in theory ... would the AWD push torque to the 2 wheels that still have traction ? Link to comment Share on other sites More sharing options...
Xantium Posted October 25, 2005 Share Posted October 25, 2005 To be honest it would probably be pushing the two wheels without traction... wheeeeeeeee stuck. Open diffs transfer power to the side with the least resistance. Link to comment Share on other sites More sharing options...
GeorgeB Posted October 25, 2005 Author Share Posted October 25, 2005 that is what i'm thinking :-/ darn ... at least you must get 2 wheels in 0 traction some 4x4 systems out there need less Link to comment Share on other sites More sharing options...
ldc2335 Posted October 26, 2005 Share Posted October 26, 2005 that sucks...so not really full time all wheel drive, more like two wheel drive, 1 front 1 rear Link to comment Share on other sites More sharing options...
nKoan Posted October 26, 2005 Share Posted October 26, 2005 that sucks...so not really full time all wheel drive, more like two wheel drive, 1 front 1 rear and most 2wd systems are really just 1wd systems one front or one rear (unless, of course, they have a LSD too). The open differentials kinda suck for getting out of snow (I've bottomed out an 04 OBS w/ open diffs front and rear), but they are still decent on dry pavement. Even with the open diffs, you still get the added performance of AWD because power is distribuited to all wheels. And its really not that bad in a slip. The center differential is still, I believe, a viscous coupling center differential, which does limit the slip (but you can't really refer to it as a limited slip differential). So, if you have the front wheel spinning, power is transfered rearward and if both those wheels have traction, then they get the power almost instantly. Same goes for the other direction, rear to front. The only problem that can occur is if one wheel up front is slipping and another wheel in back is slipping. This usually isn't a big deal if you are moving because usually within a few seconds (unless you hit a big patch of ice, but then you're fucked unless you have studs or chains on), the wheels will slip to pavement where at least one end has traction and you'll be able to pull out home free. I've driven multiple Subaru's on ice and snow with open diffs all around, and its really not that bad. Granted, I'm much happier with the LSD in the rear now, but the open diffs do help quite a bit. I still prefer it to a 2wd car in the snow. Link to comment Share on other sites More sharing options...
GeorgeB Posted October 27, 2005 Author Share Posted October 27, 2005 i have driven subaru's in the winter for the past 3 years . i'm really happy with the performance. unless you do hard offroad driving you can't get really stuck ! i did even an offroad kindda route with the impreza on mud and a lot of water and it pulled out really nice the subaru AWD is more performant that quattro and i'm happy with that Link to comment Share on other sites More sharing options...
Garandman Posted November 25, 2005 Share Posted November 25, 2005 that sucks...so not really full time all wheel drive, more like two wheel drive, 1 front 1 rear Or, just use left foot braking. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
stanjk3 Posted November 27, 2005 Share Posted November 27, 2005 Why don't they have at least one LSD on all their AWD systems?? It wouldn't add all that much to the price of the car, ot they could at least make it an option. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
nKoan Posted November 27, 2005 Share Posted November 27, 2005 The center is kind of an LSD. Link to comment Share on other sites More sharing options...
OhBe1 Posted November 28, 2005 Share Posted November 28, 2005 The Outback, OTOH, has a viscous rear diff. And viscous center diff for manuals. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
stanjk3 Posted November 28, 2005 Share Posted November 28, 2005 The center is kind of an LSD. I'd hope so, an open center diff would be pretty useless. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
