Brickle Posted December 5, 2014 Share Posted December 5, 2014 Hey guys, I was finally able to go out and pull a log tonight. I'm pretty sure I logged the right stuff. I have very little understanding of most of this stuff, but I did see some DAM adjustment and some Feedback Knock/Fine Knock Learning value changes. If someone could please go over my log and tell me how everything looks, and maybe explain what this stuff means and what I could do to fix it, it would be much appreciated. I'm fairly positive I have a failing front O2 Sensor, so that may play a role in some of the readings. The pull was in 3rd gear from around 3200rpm to near redline. I hope I logged the right things and the log holds some useful info! Thanks so much, Brickledatalog2.csv Link to comment Share on other sites More sharing options...
Brickle Posted December 5, 2014 Author Share Posted December 5, 2014 Bump! Link to comment Share on other sites More sharing options...
ragman Posted December 5, 2014 Share Posted December 5, 2014 What is your mod list? Are you running the Cobb AP Stage 1 tune? That Fine Knock learn event (-4.2) is bad, and as you can see it dropped your dam down to .75, which is will cause the ECU to pull timing. On a solid set up, DAM should always remain at 1. Link to comment Share on other sites More sharing options...
Brickle Posted December 5, 2014 Author Share Posted December 5, 2014 COBB catless UP, K&N drop in filter. COBB AP Stage 1 OTS tune for 93 Octane. Plugs and valve cover gaskets replaced at 90k. I just found out today I've been driving thousands of miles with my fuel pressure regulator vaccum line disconnected...... That probably caused a few issues. Its plugged back in now, gonna pull another log tonight after driving around to let the ECU relearn for a bit. I'll post it here! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 5, 2014 Moderators Share Posted December 5, 2014 ^^wow. I thought that was the hose that liked to pop motors when it came loose! You should just reset the ECU after fixing that, then let it relearn. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ragman Posted December 5, 2014 Share Posted December 5, 2014 You probably should be using a stock filter on that OTS tune as well. Reset the ECU. Make sure the DAM goes back to 1 before the next pull. Then log again. Link to comment Share on other sites More sharing options...
MrTris Posted December 5, 2014 Share Posted December 5, 2014 What is your mod list? Are you running the Cobb AP Stage 1 tune? That Fine Knock learn event (-4.2) is bad, and as you can see it dropped your dam down to .75, which is will cause the ECU to pull timing. On a solid set up, DAM should always remain at 1. Not just cause the ECU to pull timing, that -4.2 means it's already pulled 4.2deg of timing in a place where it expected knock to happen, hence the table, Fine Learned Knock. So, whatever conditions were present at that time, it's knocked there before, so, as a precaution, it's pulled timing whether there was an actual knock event or not. FBKC is OK, in most circumstances; what you want to see is that the ECU is pulling timing and the putting it back incrementally. It really shouldn't be pulling more than 2deg, though. FLKC, though, is where it's seen knock so much before, that it's pulling timing because it has, or should have done so in the past, regardless of a knock event. As I said in a text, check out the Cobb Tuning Support Manual -- it's got definitions of all the tables and what you should expect to see there, plus lots of helpful hints. Link to comment Share on other sites More sharing options...
Brickle Posted December 5, 2014 Author Share Posted December 5, 2014 Will do. I'll go ahead and throw a paper filter in tonight as well. I didn't even know that the AP doesn't like K&N filters until a couple weeks ago. I have a brand new paper one laying around so I'll put it in. Link to comment Share on other sites More sharing options...
Brickle Posted December 5, 2014 Author Share Posted December 5, 2014 ^^wow. I thought that was the hose that liked to pop motors when it came loose! You should just reset the ECU after fixing that, then let it relearn. Yeah.... I can't believe something catastrophic didn't happen. It's seriously probably been off for over 10k miles. The only time it could have come off is when I did the valve cover gaskets. Unless it just blew off while driving. Gonna zip tie that mofo. Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 5, 2014 Share Posted December 5, 2014 At least you still have a positive DAM and only one FLKC event- I have constant fluctuating -14 to +2 (mostly in the negatives) FLCK and a 0.000 DAM.... Link to comment Share on other sites More sharing options...
Brickle Posted December 6, 2014 Author Share Posted December 6, 2014 I'm gonna try to pull another log tonight. My fuel pressure regulator is reconnected, and I took the K&N out and dropped a paper filter in. Car is running SO much better. Link to comment Share on other sites More sharing options...
