carloverp Posted December 4, 2014 Share Posted December 4, 2014 hey everyone Im new to the forum, but it seems like theres some great info on here I picked up an 05 lgt wagon auto not long ago with a blown turbo Ive replaced the turbo and was still having some issues so I pulled the motor to change a few things and dropped it back in. Before I pulled the motor, the car would start with no issue, now when the battery is hooked up all the corner lights stay up, I also noticed that the security light was flashing on the dash intermittently, and the worst part is the car has to crank for about 10 seconds before it starts and it really hesitates to start, almost like a carb'd car that hasnt ran in a long time. Any ideas? I feel like it could be the security system acting up, but it was fine before I pulled the engine any help would be appreciated Link to comment Share on other sites More sharing options...
MrTris Posted December 4, 2014 Share Posted December 4, 2014 Did you be sure to reconnect the ground straps? As for the corner lights-- is the little switch on the steering column flipped? It activates the parking lights, even if the car isn't on, which, of course can drain the battery causing heard starts due to not enough cranking amps. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 4, 2014 Share Posted December 4, 2014 Nobody plugged in the green test contactors did they ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 5, 2014 Share Posted December 5, 2014 If the security light is on, it may be related to your immobilizer unit since you're having a hard time getting the engine to start. For instance, if you don't use the right key and try starting the car, it will just crank and never start. so yeah, check all the connections and stuff. Link to comment Share on other sites More sharing options...
