brelandt Posted November 25, 2014 Share Posted November 25, 2014 Bought my first Subbie a couple of days ago ('98 Legacy GT 5 speed) and now it's broke.....Car takes a little long to fire up but runs smooth and strong. Tonight it took 2 tries to get it to fire up but it ran fine. Almost home and I heard a noise then the check engine light came on. Drove it under the car port and I can hear the engine making a tick tick tick and the RPM's are way low. Shut it down. Will need to grab my code scanner from work and see which codes I have but no clue what the noise is yet. Too dark tonight and I'm too tired anyway. Wish me luck! Link to comment Share on other sites More sharing options...
legacy1994 Posted November 25, 2014 Share Posted November 25, 2014 scan that bitch and report back, but probably the CEL came on for the knock sensor, and what you're hearing is engine knock. could also be a valve issue though. lucky you've got an OBD2 car, that'll make diag a lot easier Link to comment Share on other sites More sharing options...
brelandt Posted November 25, 2014 Author Share Posted November 25, 2014 lucky for me I have a co-worker that use to specialize in Subbies. He did warn me about the knock sensor issue. However, sounded more like a thrown spark plug. I'll report back as soon as I get more info. Link to comment Share on other sites More sharing options...
brelandt Posted November 25, 2014 Author Share Posted November 25, 2014 P1507 - Idle Control System Malfunction (Fail Safe) Looks like all I need to do is clean the idle air valve which I was planning to do today anyhow! So bad to good luck? I'll post and update afterwards. Link to comment Share on other sites More sharing options...
brelandt Posted November 25, 2014 Author Share Posted November 25, 2014 Ok it's fixed. I removed the IACV and man was it nasty. I took the motor off and brought it to my shop and socked it in penetrating fluid and turned the valve by hand till I felt it had loosened. cleaned the part the valve in the parts washer ans scrubbed it with a brush. Afterwards I hit it with the TB cleaner and then sprayed a little shot of air tool oil. While I was at it I cleaned the MAF which was black and the TB. Cleaned the PCV and put it back together. Now she fires right up without the long crank it had before and idles great. Also the hesitation I had in 3rd gear is gone. Did a few other things to like cleaned the K&N filter and fixed my leaking P/S return hose. Drove around town and no more problems. Link to comment Share on other sites More sharing options...
Rad1134 Posted March 11, 2015 Share Posted March 11, 2015 My '99 legacy GT has a P0507 code. Can anyone tell me how to remove the IACV to clean? Youtube videos don't cut it for me. If not i probably will just have to have it replaced anyway but I hope it's not much to replace.. Link to comment Share on other sites More sharing options...
