Opus4422 Posted November 22, 2014 Share Posted November 22, 2014 I am experiencing a combined issue : 1. A higher level of engine vibration that I can feel through the shift lever and the steering wheel and even in the seats. 2. I also am having an occasional issue where it almost stalls when it is at idle. 3. I also notice a screech when starting it in very cold ( below 15 degrees) cold weather. I don't know if they could be combined or if I am looking at a variety of problems. Any input would be appreciated Link to comment Share on other sites More sharing options...
AF_3C2 Posted November 22, 2014 Share Posted November 22, 2014 High level of vibration more likely miss-fires, low enough not to set off a CEL, but can feel through the drive train. I have the same problem on mine- you have any way to monitor your ECU (Cobb AP or open source w/ Tactrix)? Start monitoring for cylinder roughness, and can be caused by fueling, air leak (upper intake manifold gaskets are notorious), fouled injector, plugs, or coil pack. The screech- does it only do it for a second or two on cold start? Time to grease up your starter shaft...if happening more often than just on cold start, might be related to throw-out bearing if you are MT. Link to comment Share on other sites More sharing options...
Opus4422 Posted November 23, 2014 Author Share Posted November 23, 2014 AF_3C2...what is Cobb AP or Tactrix?? I have a laptop is there a way to hook it up to get the readings you are talking about??? I just had the clutch replaced back in July, it took them 6 weeks to finally get it adjusted to work correctly...wouldn't they have replaced the throw out bearing when the replaced the clutch?? It is only happening in the cold however, at least it is a lot more noticeable in the cold. Where is the starter shaft?? I hae replaced a lot of starter motors over the years but never greased the shaft, so this would be new to me... Link to comment Share on other sites More sharing options...
outahere Posted November 24, 2014 Share Posted November 24, 2014 ……...Where is the starter shaft?? I hae replaced a lot of starter motors over the years but never greased the shaft, so this would be new to me... http://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html Link to comment Share on other sites More sharing options...
