namtrok Posted November 19, 2014 Share Posted November 19, 2014 hi guys! im ready to pull my ej22 out of my 95 wagon since it blew up:(( i was wondering if there was anything i need to disconnect with the clutch before removing the engine or if it will just slide off the spline? its a manual clutch, not hydraulic. thanks!!! Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 19, 2014 Share Posted November 19, 2014 I posted the FSM procedure for removing an engine here: http://legacygt.com/forums/showthread.php/blown-head-gasketi-186097.html You will need to disconnect the hill holder cable, the accelerator cable, the clutch release spring, and the clutch cable. The FSM call for removing a few unnecessary items like the charcoal canister and the AC. Just unbolt the AC compressor and you can move it to the side. Spray all the bolts a day or two in advance with PB blaster. Link to comment Share on other sites More sharing options...
namtrok Posted November 19, 2014 Author Share Posted November 19, 2014 So does the clutch fork need to come out? Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 19, 2014 Share Posted November 19, 2014 Figure 29 of the diagrams I posted show how to release the clutch fork if it is a turbo model but the flowchart at the beginning doesn't specify that you need to do that for an NA. I've only removed engines with the 4EAT. Link to comment Share on other sites More sharing options...
Osei Posted November 21, 2014 Share Posted November 21, 2014 The clutch fork stays with the tranny. Now is the time to do a careful inspection and r&r (inspect for cracks and replace the springs). O. Link to comment Share on other sites More sharing options...
namtrok Posted November 22, 2014 Author Share Posted November 22, 2014 cracks!? cracks where? also, anyone know the torque specs for the flywheels and pressure plate bolts? Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 24, 2014 Share Posted November 24, 2014 The clutch fork can crack. They aren't very beefy. Link to comment Share on other sites More sharing options...
namtrok Posted November 25, 2014 Author Share Posted November 25, 2014 So should I just replace it?! Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 25, 2014 Share Posted November 25, 2014 Wouldn't hurt since you are in there. They are about $30 or so from the dealer iirc. Link to comment Share on other sites More sharing options...
96legacyls Posted November 25, 2014 Share Posted November 25, 2014 flywheel bolts are what 58 ft/lb and clutch is 15 ft/lb something like that id have to look to make sure. leave clutch hooked up until u have motor out this is why.... leaving clutch hooked up until motor is out is easiest way to split motor from tranny is unbolt everything hop inside and push the clutch down and it will push motor from tranny for u enough to wiggle motor out and up when u pull it. also i have found it makes all this easier if you drop front half of driveshaft and and take the 4 bolts out back of tranny mount n rest it on a jack, gives better angle to pull and install new motor. Link to comment Share on other sites More sharing options...
96legacyls Posted November 25, 2014 Share Posted November 25, 2014 monkey i got my 22t rebuild done and in and running awesome thanks for advice. Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 25, 2014 Share Posted November 25, 2014 Awesome! Glad I could help. Link to comment Share on other sites More sharing options...
namtrok Posted November 26, 2014 Author Share Posted November 26, 2014 flywheel bolts are what 58 ft/lb and clutch is 15 ft/lb something like that id have to look to make sure. leave clutch hooked up until u have motor out this is why.... leaving clutch hooked up until motor is out is easiest way to split motor from tranny is unbolt everything hop inside and push the clutch down and it will push motor from tranny for u enough to wiggle motor out and up when u pull it. also i have found it makes all this easier if you drop front half of driveshaft and and take the 4 bolts out back of tranny mount n rest it on a jack, gives better angle to pull and install new motor. That's close enough!!!! That seems to be around the consensus. I'm not actually tourqing with a torque wrench, but knowing the torque I should be fine doing it by hand. Unless Subaru clutches are temperamental and should be tourqued to spec? But I remember a few Subaru techs telling me they never "torque" anything. Link to comment Share on other sites More sharing options...
twisty Posted November 26, 2014 Share Posted November 26, 2014 But I remember a few Subaru techs telling me they never "torque" anything. id smack em with a torque wrench and tell them to check everything. Link to comment Share on other sites More sharing options...
namtrok Posted November 26, 2014 Author Share Posted November 26, 2014 also does this pilot bearing get pressed in untill it is flush with the clutch side of the flywheel..... or should it be pressed in slightly farther? Link to comment Share on other sites More sharing options...
96legacyls Posted November 27, 2014 Share Posted November 27, 2014 Yea I'd smack the techs with every one of my torque wrenches lol never just wing it unless u wanna replace what u just or more. Torque wrench is the prolly the most important tool in my box. I'm glad i do all my work n don't go to those tecs Link to comment Share on other sites More sharing options...
mylegacygtwagon Posted December 3, 2014 Share Posted December 3, 2014 I pulled my ej25 and inspected everything transmission wise the fork seems to be wobbly to much and how do I replace the throw out bearing. Any help would be great! Link to comment Share on other sites More sharing options...
