Bubbaray Posted November 3, 2014 Share Posted November 3, 2014 06 Legacy Automatic I hear a whine coming from what sounds like the front of the car when I am driving. I have put it in neutral while the car was in motion and the whine stops and then as soon as I put it back into drive the whine comes back. Any suggestions would be extremely helpful Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2014 Share Posted November 3, 2014 Low on tranny fluid ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bubbaray Posted November 3, 2014 Author Share Posted November 3, 2014 nope I just checked that and I got it flushed about 6 months ago Link to comment Share on other sites More sharing options...
Max Capacity Posted November 3, 2014 Share Posted November 3, 2014 Sorry, I'm a 5mt guy, I'm out of idea's. Might be a bearing ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ItalianPasta Posted November 3, 2014 Share Posted November 3, 2014 does it change under accel/decel? turning? Only in a certain gear orrrr... more info man. Link to comment Share on other sites More sharing options...
Bubbaray Posted November 4, 2014 Author Share Posted November 4, 2014 the pitch on the whine changes when the speed of the car changes, yes the noise is still there when I am turning, and it the noise is in every gear. Thanks again Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2014 Share Posted November 4, 2014 IMO you need to talk with a automatic transmission guy, I think you have bearing issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
