mr.white4 Posted November 3, 2014 Share Posted November 3, 2014 Hi everyone, I'm looking for HID kit, and there onw thing I dont understand, where is there 35W and 55W ?? whats the difference ?? thanks alex Link to comment Share on other sites More sharing options...
redfirered Posted November 3, 2014 Share Posted November 3, 2014 The Retrofit Source is a great option, 55 Watt HIDs are a lot brighter. Is this for your High Beams or Low Beams? Link to comment Share on other sites More sharing options...
mr.white4 Posted November 3, 2014 Author Share Posted November 3, 2014 its for my low beam Link to comment Share on other sites More sharing options...
redfirered Posted November 3, 2014 Share Posted November 3, 2014 The Retrofit Source is definitely your best option. Link to comment Share on other sites More sharing options...
benfrancis Posted November 3, 2014 Share Posted November 3, 2014 http://legacygt.com/forums/showthread.php/modified-headlight-picture-thread-96284p29.html Link to comment Share on other sites More sharing options...
mikeydrives1 Posted November 4, 2014 Share Posted November 4, 2014 Avoid DDM tuning at all costs. Them along with almost all Ebay brands are poorly manufactured knockoffs that have unpredictable lifespans and behavior. Ive been dabbling with kits for many years now and in all my experiences, the very best kits you can get are either the ones through Diode Dynamics or Morimoto kits. They are pretty pricey but are quality material. 35w and 55w just denotes the wattage, in other words, how bright. Id recommend 35watt for normal reflective housings and 55watt for any car equipped with projectors. Link to comment Share on other sites More sharing options...
travrach Posted November 4, 2014 Share Posted November 4, 2014 ^ That's interesting you say that about DDM Tuning, I have had a set in 2 different cars, had them both for over 2 years and they worked fine with no issues the whole time. I will buy from them again. Curious what issues did you have? Link to comment Share on other sites More sharing options...
mikeydrives1 Posted November 5, 2014 Share Posted November 5, 2014 I used to have DDM tuning ones too on my vehicles, but for whatever reasons, the lifespan was a gamble. One set i had lasted 2+ years before they began to act up. Replaced them with the exact same kit. That kit worked for a week. Upon closer inspection, the wires were discolored and even had bare metal exposed in some areas around the ballasts, where i guess they had heated up and melted the rubber. My engine bay stunk of burnt rubber. It was the exact same kit, installed the same way as the other. Another kit i installed on my significant others legacy worked great for about a year and a half (35watt 5k h7's) before she complained that there was a funny smell. This time i found that the passenger side bulb was becoming so hot that it had warped the plastic setting it was sitting in and discolored the large plastic dome behind it that the 05+ headlights have. Again, the kit was fine for a year and a half without any issues before having this happen. After that, i said no more DDM tuning kits. I paid the higher price for Diode dynamic and morimoto kits for all 3 of our cars and have never been happier. Just the build and harness quality of the Morimoto's makes them worth their price tag. Link to comment Share on other sites More sharing options...
mdzowner Posted November 5, 2014 Share Posted November 5, 2014 my ddms are going strong 4 years not a flicker or fault. just saying. however there is nothing wrong with paying more if they are built better Link to comment Share on other sites More sharing options...
turboboost Posted November 5, 2014 Share Posted November 5, 2014 A retrofit kit from TRS will give you the absolute best results for the buck, but it's labor-intensive and a bit nerve-wracking for a first-timer. Completely worth it though. 55W will be a little brighter than the 35W, but it's recommended (but not necessary) to use a wiring harness for a direct connection to the battery due to the higher power draw. There have also been some anecdotal reports of melted housing + burnt wires though. A 35W kit is simply plug-and-play and can run off your stock wiring without the need for an additional wiring harness. Tons of people do it since it's so quick and painless. The 2 plug-and-play kits I recommend are Diode Dynamics (~$200) or Volt (~$100). Link to comment Share on other sites More sharing options...
sashadg1 Posted November 10, 2014 Share Posted November 10, 2014 ok anybody do hid high beams, is there such a thing and is there a write up anywhere on how to retrofit or is it best just to buy those 90 11 HIR bulbs and be done with it? Link to comment Share on other sites More sharing options...
travrach Posted November 11, 2014 Share Posted November 11, 2014 ok anybody do hid high beams, is there such a thing and is there a write up anywhere on how to retrofit or is it best just to buy those 90 11 HIR bulbs and be done with it? Yes you can put HIDS in the highs, you need a 9005 kit. Link to comment Share on other sites More sharing options...
GipsySpec.B Posted November 11, 2014 Share Posted November 11, 2014 I got the Xenon 55W HID kit and I love it. easy install and the 6k are super bright. I didn't have to adjust them or anything, I've yet to be flashed which I hear can happen because people think you're running with your hi-beams on. IMHO HID high beams and fogs are overkill. Link to Xenon: http://www.xenonhids.com/low-beam-h7-full-xenon-hid-conversion-kit.html Link to comment Share on other sites More sharing options...
gmentals Posted November 12, 2014 Share Posted November 12, 2014 I got the Xenon 55W HID kit and I love it. easy install and the 6k are super bright. I didn't have to adjust them or anything, I've yet to be flashed which I hear can happen because people think you're running with your hi-beams on. IMHO HID high beams and fogs are overkill. Link to Xenon: http://www.xenonhids.com/low-beam-h7-full-xenon-hid-conversion-kit.html Did you opt for the Power Relay Harness and/or the Warning Cancellers? Link to comment Share on other sites More sharing options...
GipsySpec.B Posted November 12, 2014 Share Posted November 12, 2014 Did you opt for the Power Relay Harness and/or the Warning Cancellers? I got the relay harness because I was a little worried the initial flicker before the bulbs warm up may increase the chances of blowing the filaments. aside from that I got the next stage up for the Ballasts rather than the ones that come standard with it. Link to comment Share on other sites More sharing options...
