subbiedrifting101 Posted October 31, 2014 Share Posted October 31, 2014 I am a noob at this form and this is my first Subaru(feels awesome) anyway its a 1997 Legacy GT i was driving the other day had my stereo system up pretty loud and was doing about 60 mph, then all of a sudden the car just shuts off only thing that works is the door dinger when i stopped and got out so first i tried to jump it, nothing happened took the battery to Autozone battery was fine then took the alternator there and it failed so i got a new on installed it, still nothing tried to push start , nothing again then had it towed home and my buddy that has a 2000 legacy came over we messed with the fuses under the hood and then it came on... but they were all fine not blown or anything so i just got in and started driving again just fine for a while then tuesday on my way home from work the radio turned on and off twice so i just turned it off and my heater just in case it was too much draw and i got home turned it off and noticed my courtesy lights on my door didnt come on (like last time) so i tried to start it and nothing again... can any of you could come up with where to start now i would appreciate any and all ideas!!! Thank you for reading my whole story Link to comment Share on other sites More sharing options...
GTEASER Posted October 31, 2014 Share Posted October 31, 2014 It wouldn't look so weird if you had avoided a run-on paragraph and used commas. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
doobaruGT Posted October 31, 2014 Share Posted October 31, 2014 Grounds? Just a guess, I don't know nearly enough, just want to be helpful. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
Zues Marine Posted November 1, 2014 Share Posted November 1, 2014 It wouldn't look so weird if you had avoided a run-on paragraph and used commas. he typed this without breathing Link to comment Share on other sites More sharing options...
Zues Marine Posted November 1, 2014 Share Posted November 1, 2014 check your main harness plugs also, if they get jarred loose your ECU will get no signal and similar symptoms will occur Link to comment Share on other sites More sharing options...
corlon Posted November 1, 2014 Share Posted November 1, 2014 when you say nothing happens when you try to start it, is there no click or crank or any sounds at all? is the dash lite up? dome light on? thanks. Link to comment Share on other sites More sharing options...
