xxirish83x Posted October 31, 2014 Share Posted October 31, 2014 http://youtu.be/M9moR2s2jmw Noise came about the last few days.... i would almost say with the cold weather. Little back ground.... Been running stage 2 map... bnr 18g turbo.... ect ect nothing crazy done. My car has 117k on it and has had all scheduled maintenance done relatively on time. Oil changed every 3-4k with full synthetic. Within the last 5000k i got new plugs, timing belt, water pump, thermostat, and pullys. Besids the noise there is no noticeable issues with performance or anything. Car runs great. Boost is where it should be, oil pressure is where it should be. Only happens during idle and goes away once rpm is over say..... 900-1000. Any ideas? Im thinking its the alternator Link to comment Share on other sites More sharing options...
gmentals Posted October 31, 2014 Share Posted October 31, 2014 Are you tuned for the 18g or just running a stage 2 OTS? Link to comment Share on other sites More sharing options...
xxirish83x Posted October 31, 2014 Author Share Posted October 31, 2014 Standard Cobb stage 2 Link to comment Share on other sites More sharing options...
gmentals Posted October 31, 2014 Share Posted October 31, 2014 Then I'll have to disagree with your "nothing crazy done" statement. Stage 2 ots is, what, 17 psi? That's a considerable difference in airflow compared to a vf46 at the same boost. I can't say what the noise is though. It doesn't sound good either way. When you figure it out make sure and get a proper tune for that turbo! Link to comment Share on other sites More sharing options...
xxirish83x Posted October 31, 2014 Author Share Posted October 31, 2014 yeah i know..... i have all these part i need to get installed before i get my actual tune. I have a FMIC, injectors, and fuel pump. sitting downstairs waiting to be installed. Im torn between getting the work all dialed which would most likely cost about +2g said and done or just selling my car after this winter and getting an 09 S5. Link to comment Share on other sites More sharing options...
gmentals Posted October 31, 2014 Share Posted October 31, 2014 At least get an e-tune for that turbo with your stock fueling. Its only about $150. Link to comment Share on other sites More sharing options...
xxirish83x Posted October 31, 2014 Author Share Posted October 31, 2014 At least get an e-tune for that turbo with your stock fueling. Its only about $150. im sure with some searching i can find it, but can you point me in the right direction of a reputable person/business Link to comment Share on other sites More sharing options...
gmentals Posted October 31, 2014 Share Posted October 31, 2014 Here's one. http://legacygt.com/forums/showthread.php/cryotune-performance-10-off-e-tune-and-merch-halloween-special-232738.html Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted October 31, 2014 Share Posted October 31, 2014 ^ +1 what he said. Cryotune ftw Link to comment Share on other sites More sharing options...
xxirish83x Posted October 31, 2014 Author Share Posted October 31, 2014 emailed cyro - Im taking my car in tuesday to get the noise checked out. Ill keep you posted Link to comment Share on other sites More sharing options...
xxirish83x Posted November 4, 2014 Author Share Posted November 4, 2014 Update - it was a bolt on the timing belt cover (bracket or something). backed out and was bouncing off the belt. Link to comment Share on other sites More sharing options...
