Taylormclean Posted October 28, 2014 Share Posted October 28, 2014 So my p0304 code came back. I inspected the spark plugs and the #4 plug had gray build up in the insulator, but 1-3 were white. The electrode and everything had the same color only difference was the insulator had some carbon gray color to it. I was wondering if anyone had some insight on that. Also noticed my intercooler was separating at the end tank, would this have something to do with it? Info on the car is it completely stock coming up on 140,000 miles. I had the same code pop up a couple times so I swapped injectors, coil packs and spark plugs and it still came back. It went away for about a month and then I put some gas cleaner in it and now the code is back. Link to comment Share on other sites More sharing options...
GTTuner Posted October 28, 2014 Share Posted October 28, 2014 Grey crusty build up (without seeing it) is usually oil. I'd do a compression leak down on that cylinder. Link to comment Share on other sites More sharing options...
Taylormclean Posted October 28, 2014 Author Share Posted October 28, 2014 The insulator was turning a gray color. Not crusty. I should have taken a picture. I'll see if I can get the time to take it back out. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2014 Share Posted October 28, 2014 Burnt exhaust valve. Do what he suggested. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Taylormclean Posted October 28, 2014 Author Share Posted October 28, 2014 Well poop. Alright. Thanks for the tip Link to comment Share on other sites More sharing options...
