Legacy53 Posted October 23, 2014 Share Posted October 23, 2014 Hey guys I have a 2005 legacy 2.5i and its slamming into 4th gear. I want to buy a transmission off of a 2005 outback 2.5i, do you guys know if the transmissions are the same? Thanks in advance. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted October 24, 2014 Share Posted October 24, 2014 I don't believe so, the final drive gear ratio is different. There's a sticky here about it some where. or check out JmP's sticky int he top of the 4th Gen forum. Try car-part.com to find one locally. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
