JoeNathan Posted February 23, 2015 Author Share Posted February 23, 2015 Ok, so I went back to the dealer on this one and got the "official" headgasket. I think I may have just screwed up the process on the first gasket as I pulled the engine again and suspected it was the LH side and took that head off first. Sure enough there was a small amount of water in the cylinder so I swapped out a new headgasket, put it all back together and it fires up correctly with no smoke coming out the rear. Car engine has some other issues, namely that it just feels like it's off balance. Engine has a pretty consistent rock in it and it feels like I've made my own massage chair when sitting in it. Also the power and response just seems a little lacking. No codes thrown and there's nothing that immediately says I screwed up in the behavior. Does anyone have any ideas? I replaced the LH head with a head pulled off of a forester, and was told they were identical. My question is off hand does anyone know if those cam shafts are ground different? That would explain the off balance issue as one side is running with a different timing than the other, but probably just a little bit different. Link to comment Share on other sites More sharing options...
JoeNathan Posted February 25, 2015 Author Share Posted February 25, 2015 bump for anyone who missed this Link to comment Share on other sites More sharing options...
Tr00b Posted February 25, 2015 Share Posted February 25, 2015 Do a compression test? How are the motor mounts? I don't know about different cam profiles. Link to comment Share on other sites More sharing options...
JoeNathan Posted February 25, 2015 Author Share Posted February 25, 2015 there a trick to getting those spark plugs out? i figured a few extenders and a universal angle will get it but damn gonna be a pain in the ass Link to comment Share on other sites More sharing options...
Tr00b Posted February 26, 2015 Share Posted February 26, 2015 Pull washer tank and 6-8" extension maybe a flex head rachet Link to comment Share on other sites More sharing options...
