Max626 Posted October 16, 2014 Share Posted October 16, 2014 Anyone have remote start on their BG Legacy 5spd? Im having a issue with mine, I believe I might be programming it wrong but would like like some input on how you guys went about wiring in the remote start. Btw the alarm I'm using is AutoPage C3-RS-730 Link to comment Share on other sites More sharing options...
twisty Posted October 20, 2014 Share Posted October 20, 2014 what kind of issue are you having? is it not starting? is it intermittent starting? Link to comment Share on other sites More sharing options...
Max626 Posted October 21, 2014 Author Share Posted October 21, 2014 Not starting, everything else working Locks/Unlocks shock sensor ext which leads me to believe its a issue with me programing it. But would like some input on how you went about wiring in the remote start to verify mine is correct. http://remotelystartedmn.com/admin_files/PDF/C3-RS-730install1.pdf Link to comment Share on other sites More sharing options...
twisty Posted October 22, 2014 Share Posted October 22, 2014 by that diagram, the violet wire should be triggering the blue/red wire in the ignition harness. is it wired correctly? ive never worked with the autopage brand, do you have to specify in the programming which button/ sequence is the remote start? edit: was just reading through the programming on that remote start... did you get the rpm learning part done right? ive had issues there before that would keep it from starting. and holy bijeezy, theres a lot of crap to sift through to get the features working. Link to comment Share on other sites More sharing options...
corlon Posted October 28, 2014 Share Posted October 28, 2014 was this system installed in the vehicle when you bought it or did you install it? it is not designed to work with manual transmissions. it can work with it though. there is no traditional safe way to do it. pm me for my # and I can talk you through some stuff on it. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted October 28, 2014 Share Posted October 28, 2014 While I'm not too sure about the wiring I know that I have to have the parking brake up then press the brake once before my Viper system will auto start for me. Some Auto start alarms will not even do Manual trans cars. I had to get the viper alarm. Link to comment Share on other sites More sharing options...
twisty Posted October 29, 2014 Share Posted October 29, 2014 all of them can be wired for a manual trans, its just a matter of having a neutral safety switch installed to show youre in neutral. its up to the installer to figure that part out and make it work. Link to comment Share on other sites More sharing options...
Max626 Posted October 31, 2014 Author Share Posted October 31, 2014 ^^ Yea, i just haven't had the time to go back under the dash to figure things out hopefully i get the time to this weekend... Link to comment Share on other sites More sharing options...
Max626 Posted November 3, 2014 Author Share Posted November 3, 2014 OK so i checked all my wires again and everything was good except a power wire going to my clutch bypass relay. I found a wiring diagram online on how to trick the car into thinking the clutch is depressed so it would start with the remote but I wouldn't lose my neutral safety switch feature. I have it wired in the following manner: #30 Pin Clutch wire*** #85 Pin Clutch Wire*** #85a Pin N/A #86 Pin Ground Output While Running from car alarm #87 Pin 12v Power ***I cut the lower wire from the clutch switch, the first one coming off the switch itself goes to 87, the other end to 30 But i removed the relay and pushed the clutch in and the car started, so I'm left to believe i used the wrong wires???? **Update** I believe i used the wrong wires, i think i used the cruise control switch wires….im going back under the dash to check again smh Link to comment Share on other sites More sharing options...
corlon Posted November 6, 2014 Share Posted November 6, 2014 should be a green/yellow (-) wire for the clutch. I'd use the 2nd starter (-) output so it is only active while starting and not the entire time it is remote started. 85- 2nd start (-) from remote starter 86- constant 12v 87- ground 30- green/yellow (-) clutch wire Link to comment Share on other sites More sharing options...
Max626 Posted November 10, 2014 Author Share Posted November 10, 2014 Ok so the bypass is not my issue, every time i program the alarm for remote start and attempt to start it my Fob says Engine Stop. At this point I'm kinda tired of messing with this system so ill have a buddy of mine check it out to see if he can get the remote start to work correctly.... Link to comment Share on other sites More sharing options...
Max626 Posted November 20, 2014 Author Share Posted November 20, 2014 Can i get the tach wire from the ECU? If yes what color/pin out is it? Id rather not go into the hot engine bay and tap at the coil…. *Update* I got the remote start to work, i ended up wiring in the tach wire from the alarm unit. The Instructions are misleading because it says you can run the remote start without that function but its not true. Very good alarm/remote start not as complicated as i thought before just iffy instructions. Next spring when its warmer outside ill wire in my clutch bypass relay but for now i just park in Neutral and have a dummy wire conneting the clutch switch so it thinks its pressed at all times. I understand some may think its a safety issue 9/10 i park in N so i doubt ill forget it in gear, and like i said ill take care of that next year. Link to comment Share on other sites More sharing options...
corlon Posted November 25, 2014 Share Posted November 25, 2014 sweet! Link to comment Share on other sites More sharing options...
