alyolles Posted October 12, 2014 Share Posted October 12, 2014 Hi guys, lately i have herd this weird grinding noise when i pull away and am doing less then 5MPH, it has progressively started happening more and more often. anyone know what it could be? Thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted October 13, 2014 Share Posted October 13, 2014 Drive next to a big wall with your window down see if you call tell more. We have a store next to Home Depot that you can drive around behind. Look around shopping plaza's you'll find one. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted October 13, 2014 Share Posted October 13, 2014 Hi guys, lately i have herd this weird grinding noise when i pull away and am doing less then 5MPH, it has progressively started happening more and more often. anyone know what it could be? Thanks Put it up on a lift with the little brother in car. (make sure he knows how to get it in and out of gear) have him run it in first while you listen to each wheel, wherein you should be able to discern which wheel bearing needs to be replaced soonest. Link to comment Share on other sites More sharing options...
08Legacy-GT Posted October 20, 2014 Share Posted October 20, 2014 bad pad? 2017 Subaru STI 2008 Subaru Legacy 2.5i limited Link to comment Share on other sites More sharing options...
alyolles Posted October 21, 2014 Author Share Posted October 21, 2014 Don't think it's a pad because it only does it when the car is cold and going very slowly Link to comment Share on other sites More sharing options...
