magnaflow resonator sound?
T_Altland27
Quick question I think I read it on nasioc website but I can't remember now but someone said that with a n/a el headed if you delete the resonator and put on a magnaflow that you will get more of the rumble? Just curious as to if it is true how it sound.
Remove your mufflers and start the car. see if you like that sound. You may need to replace the rusty bolts but any bolts and nuts from a hardware store will be fine. My Spec B has been mufflerless for 3 years.
Hint. PB Blaster and Anti Seize compound are your best friends. Use them every where and all threads.
Engine Build - Click Here
