Legacsti11 Posted January 14, 2015 Share Posted January 14, 2015 As a suggestion everybody that makes these threads push their Mods List in post number one it's in my opinion and most other is the proper way to run one of these threads and looks nicer. 05 Legacsti with toys, Efi Logics Tuned, Whitey Built Link to comment Share on other sites More sharing options...
STidriver86 Posted January 15, 2015 Author Share Posted January 15, 2015 As a suggestion everybody that makes these threads push their Mods List in post number one it's in my opinion and most other is the proper way to run one of these threads and looks nicer. As per your suggestion, it's been moved. Thanks for that. Also, the Compression/Leak Down tests went fine. Numbers were on the low side but well within acceptable ranges. The car is currently tuned for power at the upper end of the band when the turbo spools up all the way. I may change it to give it more power earlier but I'm not sure yet. Future plans are as follows: Cosmetic Fixes New set of splash guardsHood fit adjustmentRemove the STi badge from the back Exterior Upgrades Thinking about a small decklid wingPossibly a small front splitterMatch the back badge to the front with a custom red badge or a vinyl Lighting Upgrades Replace HIDs that were originally in the car with new 5k bulbs or LEDsAdd halo lighting and/or LED strips to headlightsLamin-X rear lens tint Mechanical Upgrades Replace worn O2 sensor (DTCs appeared repeatedly with P1153, followed by P0131. Pretty sure its a dead O2 sensor now.) & relocate it to the sensor bung on the DP.Replace oil plug with Fumoto S-Type Oil Drain Valve at next oil change.Replace TPMS Sensors-TBD- OTHER Full diagnostic service w/ dyno run to monitor existing performance & compare to last dyno tune from 12/2012.Flat-bottom steering wheel & lightweight pedals.ISC N1 Street Sport Coilover Suspension (the set that had originally been on it was removed prior to my ownership)GT Spec Rear Tower Bar (to match the GT Spec Front Tower Bar) Link to comment Share on other sites More sharing options...
SneakyGT Posted January 16, 2015 Share Posted January 16, 2015 Nice grab! Sweet lookin' and looks like its got LOTS of power under the hood! Enjoy it Link to comment Share on other sites More sharing options...
STidriver86 Posted January 16, 2015 Author Share Posted January 16, 2015 Nice grab! Sweet lookin' and looks like its got LOTS of power under the hood! Enjoy it Thanks, Sneaky. It still needs a few things and this winter weather makes me cry at how easily it gets filthy, even in silver. My dad's is OBP and one five minute drive and he's covered in road grime, especially with the brine mix they use in Southern NJ. I'm taking mine to my mechanic tonight to have the O2 sensor replaced & relocated to the bung on my COBB DP and to check my TMPS sensors and replace them as needed. Link to comment Share on other sites More sharing options...
STidriver86 Posted December 28, 2015 Author Share Posted December 28, 2015 Bump for Update Justice! Link to comment Share on other sites More sharing options...
STidriver86 Posted May 6, 2016 Author Share Posted May 6, 2016 Update! New mods & more power! Expensive? Yes. Worth it? Yes! Why? Because racecar. Link to comment Share on other sites More sharing options...
