urfsin Posted November 14, 2014 Share Posted November 14, 2014 When my stock clutch started to slip I was able to baby it and use it for another 10K -12K miles. I just had to drive "normal" and not floor it and I was fine. My Spec stage 1 clutch on the other hand started slipping and even if I drove normal it it would slip sometimes. It was just went our a lot faster than my stock clutch. +1 on getting a new flywheel with a new clutch. I think one of the main reasons my Spec clutch failed in 20K miles was because I tried to re-use my old flywheel (no resurfacing, just scuffed it up with some sand paper and cleaned off with brake clean) Slide It Sideways Link to comment Share on other sites More sharing options...
MaStaMooN Posted November 14, 2014 Author Share Posted November 14, 2014 When my stock clutch started to slip I was able to baby it and use it for another 10K -12K miles. I just had to drive "normal" and not floor it and I was fine. My Spec stage 1 clutch on the other hand started slipping and even if I drove normal it it would slip sometimes. It was just went our a lot faster than my stock clutch. +1 on getting a new flywheel with a new clutch. I think one of the main reasons my Spec clutch failed in 20K miles was because I tried to re-use my old flywheel (no resurfacing, just scuffed it up with some sand paper and cleaned off with brake clean) I don't believe in resurfacing.. just like brake rotors, Id replace it everytime for sanity sake. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2014 Share Posted November 14, 2014 Sorry, having a FW turned/resufaced has been done for ever. Nothing wrong with doing that. They only remove a few .000" My buddies machine shop evens resurfaces brake rotors on a flycutter, like a FW. It gives the rotor a better surface for the pads to bite into. You should never put a new clutch on an old "not resurfaced" FW. I even had the friction surface replaced on my Spec LWFW when I put the EJ257 in. The friction plate was $80 from Spec. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MaStaMooN Posted November 17, 2014 Author Share Posted November 17, 2014 Checked out the clutch parts they removed when installing my new one. Clutch disk material was almost nill.. maybe a mm or 2?.. The flywheel and pressure plate disks were pretty burnt up. Not scored but lots of pretty heated metal colors. I wonder if I should try and sell the stuff. Also have a stock flywheel and pressure plate assembly laying around. The weight of the stuff doesn't seem shipping friendly, as far as making any profit are concerned. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Max Capacity Posted November 17, 2014 Share Posted November 17, 2014 The SMFW may be worth something if it was re-surfaced. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted November 18, 2014 Share Posted November 18, 2014 Hmmm... is your stock FW single mass? I'm using my phone and can't see your car info. Today my clutch started slipping in 3rd so I think my time is very near. Sent from your mother's house My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2014 Share Posted November 18, 2014 I was kind of searching there, 05-06's came with DMFW. You don't want one of them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted November 18, 2014 Share Posted November 18, 2014 Well thanks for getting me all worked up haha. Sent from your mother's house My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
MaStaMooN Posted November 18, 2014 Author Share Posted November 18, 2014 Yeah stock FW in 05 is DMFW, but I also have the SMFW.. but would require a WRX clutch I believe. New clutch is starting to feel nice.. have about 70 miles on it so far. Still stalled it once today, whoops. Shifts really nice though. Have to wait till break in is over before I can really put it through its paces. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Max Capacity Posted November 18, 2014 Share Posted November 18, 2014 I seem to recall, the 06-11WRX is the same FW as the 07-09 and may be 12 GT's. Check some of the clutch manufactures sites and see if the some clutch part numbers work 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
