need bb Posted September 21, 2014 Share Posted September 21, 2014 I recently noticed that every time I increase my throttle angle (aka tip-in) the car has a very brief lean spike. I know that either rich/lean tip in is a common issue for those with aftermarket injectors. I believe I have had this issue for a long time since I see the issue from some WOT logs back from 2012. I originally had my tip in enrichment table scaled to 61% of the stock values to account for my larger DW 850cc injectors. I then went back to the stock tip in enrichment values and the issue still exists. I believe my issue is more complicated than just tuning the tip in enrichment table, since the stock enrichment table should have made my tip in too rich. My MAF scaling is spot on and learning view for all ranges is within 2%. I am wondering if my fuel injector latencies are too low or if my injectors need to be cleaned? Any insight would be greatly appreciated. Link to comment Share on other sites More sharing options...
need bb Posted September 23, 2014 Author Share Posted September 23, 2014 Nobody else ever had this issue? What are people running for injector latency for the DW 850cc sidefeeds? Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 24, 2014 Share Posted September 24, 2014 Does it have the same problem with stock injectors? Link to comment Share on other sites More sharing options...
need bb Posted September 25, 2014 Author Share Posted September 25, 2014 Does it have the same problem with stock injectors? I don't know. I have been running the DW 850cc injectors for 4 years now. The engine was rebuilt recently and while tuning I noticed the lean spike. My logs from 2 years ago still show the issue, but I never noticed it. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 27, 2014 Share Posted September 27, 2014 Have you made any changes to the tip in enrichment activation tables? Link to comment Share on other sites More sharing options...
need bb Posted September 28, 2014 Author Share Posted September 28, 2014 Yes. I originally was scaled to 60% of stock since I was running larger injectors. I even tried the stock tables and it was a tad better but still lean. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 28, 2014 Share Posted September 28, 2014 I mean the tables that determine when tip in is activated. They should be right beneath the tip in enrichment table. One should be based on ipw and the other tps. Link to comment Share on other sites More sharing options...
need bb Posted September 29, 2014 Author Share Posted September 29, 2014 I took a screenshot of all my settings. How does this compare with your tip in settings? Link to comment Share on other sites More sharing options...
BrandonspecB Posted October 3, 2014 Share Posted October 3, 2014 That's pretty close to what I'm using with my 900cc injectors. My car goes rich on tip in. I honestly don't know anything else to try. Link to comment Share on other sites More sharing options...
need bb Posted October 4, 2014 Author Share Posted October 4, 2014 That's pretty close to what I'm using with my 900cc injectors. My car goes rich on tip in. I honestly don't know anything else to try. Thanks. It is weird since it goes slightly rich then then it goes lean, then back to rich. Link to comment Share on other sites More sharing options...
