98 Ej22D-T LGT
Hey guys wanted to start a journal for my 98 Legacy Gt
Car was purchased in the winter of 2012 and currently drive it as my daily
http://i57.photobucket.com/albums/g238/beauchemin/Boostedsleeper.jpg
Mod list:
Engine/exhaust
Under construction!
Exterior
Outback front bumper setup
Nokya yellow bulbs for the fogs
Interior
02 Wrx Momo Steering Wheel
Oem Lamco Boost Gauge
Suspension
H&R lowering springs on stock struts
Brakes
Stock
Wheels
Stock Lgt wheels i sprayed gold
Hankook Ventus v4 215/55r16
When i bought the car it did come with stock gt "snowflake" wheel, 1 with a crack so got one from a pull yard and decided to paint them up
Sanded down and used a can of etching primer
http://i57.photobucket.com/albums/g238/beauchemin/Wheelprimer.jpg
Then a few coats of gold and clear coat
http://i57.photobucket.com/albums/g238/beauchemin/Wheelspaint.jpg
Was able to score some Hankook Ventus v4 215/55r16 for cheap
http://i57.photobucket.com/albums/g238/beauchemin/Tires.jpg
http://i57.photobucket.com/albums/g238/beauchemin/FreshWheels.jpg
With almost 200k on the stock ej25d its ready for a now heart, im currently working on a DOHCEJ22-T build
Stock ej25d intake mani, i stripped down, cleaned up and painted
http://i57.photobucket.com/albums/g238/beauchemin/Manifoldtapped.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Manifildprimed2.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Intakemanipaitedddd.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Cleanedfuelrail.jpg
I have a set of ej25d heads as well, they are modded with a coolant and oil return
http://i57.photobucket.com/albums/g238/beauchemin/Maniheadsreturn.jpg
Also did some cleanup on the heads
http://i57.photobucket.com/albums/g238/beauchemin/Clean25head.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Exhaustports.jpg
When i got the car it had the stock lgt front bumper but car had been in a small accident and the front bumper support was bent and never replaced, my buddy scored me a outback support bumper and fogs that weren't tag on a car that came into the scrapper
http://i57.photobucket.com/albums/g238/beauchemin/Faceless.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Frontbumpersuport.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Outbackbumper.jpg
My Lamco gauge
http://i57.photobucket.com/albums/g238/beauchemin/Lamco.jpg
My wife and I purchased our first home and had been working on the sucking up both money and time, but i now am officially a home owner and have a garage to work in
http://i57.photobucket.com/albums/g238/beauchemin/LeggyGarage2.jpg
No pics but got my inner/outer tie rods and lower ball joints in, as well as replaced my leaky power steering pump
Ej22e with 134XXX on it
http://i57.photobucket.com/albums/g238/beauchemin/Ej22build.jpg
Parts came in!!
http://i57.photobucket.com/albums/g238/beauchemin/HybrindGaskets.jpg
Ej222 headgaskets match up perfect with the ej25d heads
http://i57.photobucket.com/albums/g238/beauchemin/Ej222HeadGaskit.jpg
How it looked when i pulled of the 2.2 heads
http://i57.photobucket.com/albums/g238/beauchemin/Pistondirty.jpg
Cleaned up the pistons and replaced the rings
http://i57.photobucket.com/albums/g238/beauchemin/Pistonrings.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Pistonclean.jpg
New rear main seal as old one looked like was leaking a little, also got the separator plate as the 2.2 motor has the plastic garbage cover on it originally.
http://i57.photobucket.com/albums/g238/beauchemin/Oilseprearmain.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Rearmainoilinstalled.jpg
Cleaned up the block a little, here is a pic to compare to the one above
http://i57.photobucket.com/albums/g238/beauchemin/Cleanbellhousing.jpg
Heads bolted up
http://i57.photobucket.com/albums/g238/beauchemin/EJ22DTheadsmount.jpg
As well as intake mani and a new knock sensor
http://i57.photobucket.com/albums/g238/beauchemin/EJ22DTIntakeon.jpg
http://i57.photobucket.com/albums/g238/beauchemin/EJ22DTintake2.jpg
WASHED!!!!
http://i57.photobucket.com/albums/g238/beauchemin/Lgtwash.jpg
Stock EJ25D
http://i57.photobucket.com/albums/g238/beauchemin/StockEJ25D.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Parked.jpg
Daughter snapping tons of pics while we were out and about haha, first interior pic!!
http://i57.photobucket.com/albums/g238/beauchemin/Interior.jpg
Water pump and 10mm oil pump install
http://i57.photobucket.com/albums/g238/beauchemin/10mmoilpump.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Oilwaterpulled.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Oilwaterinstalled.jpg
Out with the old and in with the new
http://i57.photobucket.com/albums/g238/beauchemin/Mounts.jpg
Oil feed, used a 12x1.25mm to -4an fitting on the rear gallery
http://i57.photobucket.com/albums/g238/beauchemin/Oilfeedrear.jpg
Timing belt installed
http://i57.photobucket.com/albums/g238/beauchemin/Timingbeltinstall.jpg
I had a little fun a mocked it up on the stand
http://i57.photobucket.com/albums/g238/beauchemin/Fitment2.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Fitment3.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Updownpipefitment.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Updownpipe2.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Updownpipefit.jpg
Clutch!
http://i57.photobucket.com/albums/g238/beauchemin/Clutch1.jpg
Stopped by the Subaru dealer and scooped up my thermostat. Got an oil filter while i was there as well.
http://i57.photobucket.com/albums/g238/beauchemin/Statoilfilter.jpg
So my buddy is awesome!!! abd gave me this full lamco pack
A wrx came through the yard, there were no tags for the pack so he grabbed them for me, has the full harness still was plug and play!! It is just missing a oil temp sensor, but moved over my boost line so boost and volts are good, oil temp soon to come
http://i57.photobucket.com/albums/g238/beauchemin/Lamco6.jpg
Swapping!!!
Out with the old (206,445k)
http://i57.photobucket.com/albums/g238/beauchemin/Swap1.jpg
My little bro hooking it up with clean up while i swapped over some brackets and such
http://i57.photobucket.com/albums/g238/beauchemin/Swap2.jpg
Build is in!!!!!
http://i57.photobucket.com/albums/g238/beauchemin/Swap3.jpg
Fitting up the turbo and moving foward
http://i57.photobucket.com/albums/g238/beauchemin/Swap5.jpg
Picked up a 02 wrx momo wheel the other day and was able to slap it in last night. So much better thank the stock Lgt wheel!!!!
Out with the old
http://i57.photobucket.com/albums/g238/beauchemin/WheelLgt.jpg
In with the new
http://i57.photobucket.com/albums/g238/beauchemin/WheelMomo.jpg
Thanks man!! I actually just hit 2000 miles on the build and has been running great, i copied my build thread from sl-i and posted it here so reading it may sounds funny ill have to go and edit it some lol, i do still need to install the pp6 and wideband though. I justbgot those in the otherday
That BPV line looks like it needs snugged up on there.
And I have to ask. What's the blue accordian tube off the intake?
Yeah the bpv line has been snugged up and ziptied, thanks for looking out, the high preformance pool hose hahahha!!!! It is recirulating my bpv, if i let the bov vent to atomosphere my car wont run at idle per the maf based motor i have, pool hose will shortly be upgraded to something more suitable haha
  • 3 months later...
It has been a while since i have been able to work on the leggy, planning my wedding has been sucking up all my time and money. But i buy a new Bosch wideband sensor and wired in my Lc-1. Now just need to find time to get the Smt 6 in and start getting the most out of it
http://i57.photobucket.com/albums/g238/beauchemin/Db1.jpg
  • 2 weeks later...
  • 4 weeks later...
  • 3 months later...
Ok so it's been a while since I've been on but I have made a little progress on the legacy. The clutch couldn't handle the boost anymore (Why I put a stock clutch in...idk) and the motor started to leak a little oil so out she came
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_8.jpg
The cheapo eBay header (that I had to stretch to fit) ended up rubbing against a line in my rack so much it made a hole and started to leak fluid. So grabbed a rack and decided to swap to the legacy ss subframe
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_9.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_11.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_10.jpg
Then yesterday I took myself on a little road trip
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_16.jpg
And got a great deal on a ej255
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_15.jpg
http://i57.photobucket.com/albums/g238/beauchemin/Mobile%20Uploads/image_14.jpg
This is looking awesome. I have the EJ22 in my 1997 Legacy L, and shes got 205k, and still runnin real strong. not tickoring or anything. Do you know if anything else happened to the EJ22 you had in that? If its just leaking? I may want to buy it from you. (Vid of the engine, and the car itself lol skip to 4:30 for the startup
