Demonic13 Posted September 7, 2014 Share Posted September 7, 2014 I have a 2007 Subaru legacy non turbo. I dont want to dump lots of money into it and I dont want a gt. I have a camaro z28. With my legacy I am having a little fun with it by getting the rallisport uel header. I plan on deleting the cats. My question is about the cel. In my research I found out you can not use a spacer or non fouler on the 07's due to the denso ecu, they don't work and tuning to delete the code will later lead to other problems. Has anyone figured anything out or have been successful deleting cats on there 07 legacy? Link to comment Share on other sites More sharing options...
Mantikor Posted September 7, 2014 Share Posted September 7, 2014 I have a 2007 Subaru legacy non turbo. I dont want to dump lots of money into it and I dont want a gt. I have a camaro z28. With my legacy I am having a little fun with it by getting the rallisport uel header. I plan on deleting the cats. My question is about the cel. In my research I found out you can not use a spacer or non fouler on the 07's due to the denso ecu, they don't work and tuning to delete the code will later lead to other problems. Has anyone figured anything out or have been successful deleting cats on there 07 legacy? if u have open port 2.0 pm me, i try to help u. Link to comment Share on other sites More sharing options...
Demonic13 Posted September 8, 2014 Author Share Posted September 8, 2014 if u have open port 2.0 pm me, i try to help u. I'm not sure what you mean port 2.0? I have a stock ej253 motor. Its a 2.5 Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 8, 2014 Share Posted September 8, 2014 I'm not sure what you mean port 2.0? I have a stock ej253 motor. Its a 2.5 Delete the cats or not youll lose a slight amount of power going UEL on that engine. However if you go with the RalliSport header and want to insure against the dreaded P0420 buy a Tactrix 2.0 cable, pull a copy of your stock ECU map and disable the p0420 DTC code in the DTC section of your map and reflash it to your car. Link to comment Share on other sites More sharing options...
Demonic13 Posted September 9, 2014 Author Share Posted September 9, 2014 Delete the cats or not youll lose a slight amount of power going UEL on that engine. However if you go with the RalliSport header and want to insure against the dreaded P0420 buy a Tactrix 2.0 cable, pull a copy of your stock ECU map and disable the p0420 DTC code in the DTC section of your map and reflash it to your car. Is there a link in these forms somewhere explaining a step for step guide on how to do this that you can provide for me? Thanks Link to comment Share on other sites More sharing options...
Mantikor Posted September 11, 2014 Share Posted September 11, 2014 Is there a link in these forms somewhere explaining a step for step guide on how to do this that you can provide for me? Thanks First of all U need tactrix OpenPort 2.0 cable. Link to comment Share on other sites More sharing options...
Mike07LGT Posted September 11, 2014 Share Posted September 11, 2014 Sounds like alot of work and a waste of money to get little to no gain... but hey "have fun" with it! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Demonic13 Posted September 12, 2014 Author Share Posted September 12, 2014 Sounds like alot of work and a waste of money to get little to no gain... but hey "have fun" with it! Yeah I gave up. Not wasting money for little to no gain. And risking cel. I am now saving for an sti. Thanks guys. Link to comment Share on other sites More sharing options...
