spec chode Posted September 1, 2014 Share Posted September 1, 2014 Hey guys so I want to replace the struts and springs on my 05 gt and am wondering if anyone has any knowledge on how to raise the car at the same time, either by using struts and springs from a different model or by just using the lift kits I've seen around. My car is low, like tucking tire low, and I live in Colorado, not exactly what I want you know. Oh and it's a sedan. Link to comment Share on other sites More sharing options...
gtonstilts Posted September 1, 2014 Share Posted September 1, 2014 you can bolt outback struts and springs right up will give you a 2.5-3 inch lift, i just did the opposite to my outback and installed legacy suspension for about a 3 inch drop. my old parts are for sale in the classified Link to comment Share on other sites More sharing options...
covertrussian Posted September 2, 2014 Share Posted September 2, 2014 Your car probably has aftermarket lowering springs, get some stock springs and you will have about 2-3" wheel gap. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
spazlamhaslam Posted September 2, 2014 Share Posted September 2, 2014 you can bolt outback struts and springs right up will give you a 2.5-3 inch lift, i just did the opposite to my outback and installed legacy suspension for about a 3 inch drop. my old parts are for sale in the classified All you need is the struts and springs? no change in CV axles or anything like that? Id love to bring my leg up..I can barely make it over speed bumps. Link to comment Share on other sites More sharing options...
Dujo Posted September 2, 2014 Share Posted September 2, 2014 Just struts and springs will function, but the geometry will be bad. Search here for numerous threads on how to swap Outback to LGT and do the opposite. Link to comment Share on other sites More sharing options...
spazlamhaslam Posted September 6, 2014 Share Posted September 6, 2014 Just struts and springs will function, but the geometry will be bad. Search here for numerous threads on how to swap Outback to LGT and do the opposite. Explain geometry please? as in I won't get my car to align afterward? Link to comment Share on other sites More sharing options...
spazlamhaslam Posted September 6, 2014 Share Posted September 6, 2014 also.....I have a buddy with an 05 Baja. Are those strut and springs higher? will they fit? He wants to trade straight across. Link to comment Share on other sites More sharing options...
