jcs Posted August 30, 2014 Share Posted August 30, 2014 At first I thought my mileage had improved...then I realized the gauge is stuck on F. Anyone have any ideas? I disconnected/connected battery. No change. The gauge cycles up/down on start up as usual. Just goes to full. I just had to change the alternator. Any chance that had anything to do with it? 05 LGT LtD Wagon 5MT thanks! Link to comment Share on other sites More sharing options...
1055 Posted August 30, 2014 Share Posted August 30, 2014 fuel level sending unit. 9 years of garbage in the tank corroding the terminals, bet its stuck up. Take it out and clean the contacts, or just replace it. Its basically a rheostat resistor, so there is always the chance that one side of the circuit is shorted to ground or positive.. but most likely the sending unit. Link to comment Share on other sites More sharing options...
firehawk618 Posted August 30, 2014 Share Posted August 30, 2014 Lift the fuel pump access under the rear seat. Unplug the electrical connector. If the gauge now goes to empty you have found your culprit. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
