Winesalot Posted August 27, 2014 Share Posted August 27, 2014 I do not have any light behind the heater controls on my 95 legacy sw. Before I start tearing stuff apart are their actually lights behind there and does the bezel surrounding the controls just pop off? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted August 27, 2014 Share Posted August 27, 2014 http://legacygt.com/forums/showthread.php/instrument-cluster-hvac-control-lightbulb-replacement-walkthrough-221779.html Link to comment Share on other sites More sharing options...
Stevo F Posted August 30, 2014 Share Posted August 30, 2014 http://legacygt.com/forums/showthread.php/instrument-cluster-hvac-control-lightbulb-replacement-walkthrough-221779.html What Zues said... It's an easy fix... can get LED's thru Superbright LED's or get OEM replacements off Ebay http://www.ebay.com/itm/200922374937?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Link to comment Share on other sites More sharing options...
Winesalot Posted August 30, 2014 Author Share Posted August 30, 2014 Awesome. Thanks for the extremely helpful replies. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 30, 2014 Share Posted August 30, 2014 Hold the phone. Before you go replacing those lights, make sure you know what youre doing. No offense here, just speaking from experience. If you put too much strain on the cable going to the heater core (held on with a C clip on the bottom) it will mess you all up. Im not sure what happened but i assume it came off of the other end and now i cant adjust my air temp. Just a heads up. Link to comment Share on other sites More sharing options...
Stevo F Posted August 31, 2014 Share Posted August 31, 2014 Actually that is true- the clips on the cables were the only tricky part. I wasn't too good with the C-clips and lost one of them. Actually the cable stays on without it, so it's been OK for the past year since I replaced the bulbs. Link to comment Share on other sites More sharing options...
Zues Marine Posted August 31, 2014 Share Posted August 31, 2014 mmmmyeah just go slow and youll be aight Link to comment Share on other sites More sharing options...
