Kodybarbera Posted August 24, 2014 Share Posted August 24, 2014 hey guys, just got back from a week vacation in OBX and my car sat at home all week. today I got back and went to my friends. I came to a stop sign and it was sputtering bad. I gave it gas and it went fine then my CEL started to blink so I pulled into an access road and checked my oil, it was fine. pulled the codes, pending misfire on cylinders 2 and 4. started the car up and started driving then got CEL and blinking cruise for the misfire codes. I cleared them out and the car ran fine. idles fine and everything. I'm just going to assume the car got funky from sitting for a whole week (never usually goes longer than 2 days sitting) but I would like to get some other opinions from you guys. thanks! Link to comment Share on other sites More sharing options...
05subileggygt Posted August 24, 2014 Share Posted August 24, 2014 Missfire. Bad injectors. Plugs wire etc. low compression. Or a bad injector seal Link to comment Share on other sites More sharing options...
Kodybarbera Posted August 24, 2014 Author Share Posted August 24, 2014 it's running fine now. no more CEL. could it possibly just be from sitting that week? Link to comment Share on other sites More sharing options...
firehawk618 Posted August 24, 2014 Share Posted August 24, 2014 Sitting a week doesn't cause a misfire. I had a coil pack fail suddenly very recently. No real symptoms. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
Kodybarbera Posted August 24, 2014 Author Share Posted August 24, 2014 I was thinking maybe like some moisture or the gas got weird. hmm. we'll see if the problem persists Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2014 Share Posted August 24, 2014 Make sure the wires are all clean and tight in the coil connector. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
