itzed Posted August 16, 2014 Share Posted August 16, 2014 Does anyone have a picture they can upload showing the location of this? I've looked for it several times and can't find it. The manual seems to indicate that it's accessible from the top (see photo), but I don't see it. I can see the cat clearly from the top, but see nothing that looks obviously like an O2 sensor. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 16, 2014 Share Posted August 16, 2014 Under the car, halfway back, in the exhaust right behind the second catalytic converter in the down pipe Link to comment Share on other sites More sharing options...
itzed Posted August 16, 2014 Author Share Posted August 16, 2014 Wow, that's a ways back there - didn't expect it to be back that far. I'll look tomorrow. Does anyone else think this Japanese drawing makes it look like it's under the hood? Link to comment Share on other sites More sharing options...
itzed Posted August 17, 2014 Author Share Posted August 17, 2014 Found it. I have a normally aspirated 2006 legacy and I'm posting this for the future in case anyone else is looking for it. The front and the rear sensors are very close together, and accessible, or at least viewable, from under the hood. You can see them in this photo. The rear one is almost directly under the air box, which it have removed here. I found it much easier to remove from under the car, having removed the lower front panel that hides the radiator drain plug, and the right front wheel. After 184,000 miles, I was able to put an open end 22 open end wrench on it and with moderate force it came right off. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 18, 2014 Share Posted August 18, 2014 My apologies. I didn't pay enough attention when I answered. The LGT rear 02 is where I stated, on the end of the DP by the rear catalytic converter, but on the N/A (which you found already) they are much closer to the front. Link to comment Share on other sites More sharing options...
itzed Posted August 19, 2014 Author Share Posted August 19, 2014 No problem, I'm just glad I found it and it was easy to get to and get off. Because.... It looks like I'm going to need to go back in and try the spark plug non-fouler method of taking it out from the stream enough to get rid of the P0420 code. Link to comment Share on other sites More sharing options...
