HDZ32 Posted August 13, 2014 Share Posted August 13, 2014 So it sounds an awful lot like my wheel bearing is dying on my DS front wheel, figure it needs to be replaced :/ From my experience this is a total bitch to do, any tips/tricks? Also what's the best place to be buying a new one? Thanks in advance guys! Link to comment Share on other sites More sharing options...
ruthlessromeo Posted August 13, 2014 Share Posted August 13, 2014 I did mine a while back from instructions i found on here.. its really not that bad as our car you replace the whole assembly and dont have to get anything pressed. http://legacygt.com/forums/showthread.php/front-wheel-bearing-diy-walkthrough-86994.html?highlight=replacing+wheel+bearing Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 http://legacygt.com/forums/showthread.php/success-non-oem-wheel-hub-bearing-units-221269.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HDZ32 Posted August 14, 2014 Author Share Posted August 14, 2014 This should be all I need, thanks big time guys! Will keep you updated on it. Link to comment Share on other sites More sharing options...
HDZ32 Posted September 1, 2014 Author Share Posted September 1, 2014 So I replaced the bearing about a week ago with a new one from Detroit Axle for like 40 bucks, I figured hell yeah, that's super cheap. Well now the same wheel sounds like its going bad again. Is Detroit Axle a cheap brand or did I do something wrong? Any input is appreciated. Link to comment Share on other sites More sharing options...
ruthlessromeo Posted September 2, 2014 Share Posted September 2, 2014 i paid 150 from fred beans for mine so defenitly cheap not sure on the quality... looking on amazon there is a detroit axle bearing for our car with 4 good reviews so maybe just got a defective one there is a post here on them too.. http://legacygt.com/forums/showthread.php/success-non-oem-wheel-hub-bearing-units-221269.html?t=221269&highlight=Detroit+Axle Link to comment Share on other sites More sharing options...
