whiteout Posted August 12, 2014 Share Posted August 12, 2014 I'm changing the coolant and hoses (I've found 14 so far) on my 2005 GT wagon. The Subaru coolant with additive appears clean. When I removed the small coolant hose between the filler tank and the turbo, the coolant was dark and I wiped some black crud out of the hose with a paper towel. Haven't found this in any of the other hoses. Any ideas on what caused this? john Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 heat. I wouldn't worry to much. FWIW, I replaced both caps a while back, just because they were 10 years old. You might want to think about that. See what the rubber seals look like. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
