P0171 System too Lean (Bank 1)
I tried cleaning the maft sensor. Reset using my accessport. Was good for about a week and the code P0171 was thrown again. Hoping this is not an omen of things to come:rolleyes: Anybody with experience on the causes of this code please share.
Check these off one by one.
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty
    Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor
  • Possible cracked vacuum or PCV line/connection
  • Faulty or stuck open PCV valve
  • Failed or faulty oxygen sensor (bank 1, sensor 1)
  • Sticking/plugged or failed fuel injector
  • Low fuel pressure (possible plugged/dirty fuel filter!)
  • Exhaust leak between engine and first oxygen sensor
My wife's balls are delicious.
