08subieLGT Posted July 30, 2014 Share Posted July 30, 2014 I figure i post this local. I have 99 Nissan Altima. The signal and hazard lights don't work. I've tried new fuses and bulbs. None of the sockets are corroded. I replaced the flasher. When I put in new fuses and turn on the signal or hazard light. It will blow the fuse. What else am I missing? And any shops that you recommend getting this fixed? I'm located in NJ. Thanks in advance for your help Link to comment Share on other sites More sharing options...
liljonson Posted July 30, 2014 Share Posted July 30, 2014 you have a short somewhere. It's either wiring,socket or switch. Check the connectors for corrosion and was the car hit at all in the front end? Link to comment Share on other sites More sharing options...
