CousinLarry Posted July 22, 2014 Share Posted July 22, 2014 On my 05 GT. Drove to work and AC was frosty cold. Parked at work, went out on my lunch break, turn on the AC and nothing.. Just warm air and the compressor doesn't even kick on. So I went and got a bottle of 134a and hooked it up. Zero pressure. I started fillig and a minute later the compressor kicked on. I kept filling to correct pressure and the air coming out felt a bit cooler. It was late at night so I just shut it off and went inside. This morning, I put it on and nothing again. No compressor. So I'm guessing there's a nice leak in the system somewhere. What is the best way to find it? I've never really looked for an AC leak so don't know where to start! Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
boxman Posted July 22, 2014 Share Posted July 22, 2014 You can buy 134a with UV dye in it and use a black light to find the leak. [ame=http://www.amazon.com/Interdynamics-AFK-11CS-Arctic-Synthetic-Recharging/dp/B001810SHA/ref=sr_1_21?s=automotive&ie=UTF8&qid=1406040585&sr=1-21&keywords=ac+leak]Amazon.com: Interdynamics AFK-11CS Arctic Freeze Ultra Synthetic Recharging Kit with UV Dye and UV Light: Automotive[/ame] Link to comment Share on other sites More sharing options...
Hitokiri_Gensai Posted July 26, 2014 Share Posted July 26, 2014 Second on the dye. A lot of autoparts stores will sell uv dye kits, with the UV light and glasses for like 20 - 25 bucks. Id def give that a try and see if you can detect the leak. Link to comment Share on other sites More sharing options...
Andy_Mac Posted August 5, 2014 Share Posted August 5, 2014 Or connect it up to a bottle of nitrogen and crank that to 100psi or so and you should hear it hissing from somewhere If its readily available of course 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
