LivingTheLegacy Posted July 20, 2014 Share Posted July 20, 2014 So I've recently put my car back together with forged internals, catless up pipe, lightweight crank pulley, new oil pick up and pump, new timing components and an air intake. Everything else is stock, back together with a rebuilt VF39 and I can't seem to push over 9psi MAX! At rest its got 20inHg vacuum, ~16inHg once in drive. Boost leak stuck waste gate? Any tricks to find a leak besides smoke test? Link to comment Share on other sites More sharing options...
cryo Posted July 20, 2014 Share Posted July 20, 2014 Did you make sure to keep the restrictor pill in line between the compressor and the t? That's the most common reason for low boost after a turbo swap if your still running the stock ebcs. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
LivingTheLegacy Posted July 20, 2014 Author Share Posted July 20, 2014 I'll check, thanks! Link to comment Share on other sites More sharing options...
LivingTheLegacy Posted July 20, 2014 Author Share Posted July 20, 2014 .... Looked up restrictor pill because I wasn't sure what it was, I think you're on to something, thanks again brotha. Link to comment Share on other sites More sharing options...
