twigs Posted July 16, 2014 Share Posted July 16, 2014 When I press the button on my 2008 GT remote nothing happens..so I replaced the remote battery and still nothing happens..so I took out the spare and try pressing the buttons and things would work intermittently or not at all. Any idea what is going on... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 17, 2014 Share Posted July 17, 2014 Start the car and move it. Then try again. Seem to recall, I one of my fob's stopped working once when I parked at the dealership to pick up parts. I replaced the battery. Still wouldn't work. When I got home everything was back to normal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
twigs Posted July 17, 2014 Author Share Posted July 17, 2014 Wish it was that easy..but not go here Link to comment Share on other sites More sharing options...
lockmedic Posted July 17, 2014 Share Posted July 17, 2014 Does the key minder chime go off even when there's no key in the ignition and the driver's door is open? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 17, 2014 Share Posted July 17, 2014 Can you start the car ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
twigs Posted July 17, 2014 Author Share Posted July 17, 2014 Does the key minder chime go off even when there's no key in the ignition and the driver's door is open? nope ..all quite Link to comment Share on other sites More sharing options...
twigs Posted July 17, 2014 Author Share Posted July 17, 2014 Can you start the car ? Yes the car starts with that key.. Link to comment Share on other sites More sharing options...
twigs Posted July 18, 2014 Author Share Posted July 18, 2014 Problem Solved: I went an open the spare remote and saw the battery position then realized that I put the battery in the other remote upside down. Now the other remote works find..the spare battery look like it will need to be replace soon to being it has been in there since 2008..hence why the spare remote worked intermittently... Thanks everyone for your help... Link to comment Share on other sites More sharing options...
